Stock TQ arm doesn't like lifting a 3440# car.
Old Jul 11, 2005 | 09:53 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
If someone can host pics I'll email them to ya. My tq arm tried to rip itself of of the rear.
Old Jul 11, 2005 | 10:29 AM
CaysE's Avatar
You can post pictures here as long as they are within the size limits. If they are too large, PM me your email address and I'll resize them.
Old Jul 11, 2005 | 03:26 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
EMAIL SENT
Old Jul 11, 2005 | 05:37 PM
CaysE's Avatar
Wow!
Attached Thumbnails Stock TQ arm doesn't like lifting a 3440# car.-tq-arm-bent.jpg
Old Jul 11, 2005 | 05:38 PM
CaysE's Avatar
Attached Thumbnails Stock TQ arm doesn't like lifting a 3440# car.-tq-arm-hole-1.jpg
Old Jul 11, 2005 | 05:39 PM
CaysE's Avatar
Attached Thumbnails Stock TQ arm doesn't like lifting a 3440# car.-tq-arm-hole-2.jpg
Old Jul 11, 2005 | 07:32 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
thats a stock one? With missing inserts? Mines a solid stamped part.
Surprised it didnt rip the trans tailshaft mount.
Looks like time for an aftermarket
Old Jul 11, 2005 | 09:24 PM
CheezX's Avatar
Looks like the bolts weren't tight enough.
Old Jul 11, 2005 | 09:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It looks more like someone used hardware store bolts without the shoulder.
Old Jul 11, 2005 | 11:11 PM
CheezX's Avatar
Ah, ya one-upped me there!
Old Jul 11, 2005 | 11:35 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Shoulder...?
*mental note to go check hardware store bolts...*
Old Jul 11, 2005 | 11:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Torque arm bolts are M14 x 2 x 185, but only the last inch or so is threaded.
Old Jul 12, 2005 | 07:12 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Wrong, the bolts were tq to spec and they were OEM that rolled off the assembly line. It also broke the 9" gear casing, and striped the splines out of the stock DS.
I now have a 3" shaft w/ a forged yoke, nodular iron case, and a jegster tq arm. Much better.
Old Jul 12, 2005 | 01:59 PM
CheezX's Avatar
Well there was the problem!
Old Jul 12, 2005 | 02:02 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
opinions on the jegster arm?
Old Jul 12, 2005 | 06:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It doesn't sound like the problem was with the torque arm then.
Old Jul 12, 2005 | 08:00 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Where the TQ arm bent it was not from the DS hitting it. How do you suggest that it was bent?
Old Jul 12, 2005 | 08:02 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Much better peice. Although to install it right, you need to pull the front seats out and the carpet. Otherwise you can't get all 12 bolts drilled thru the tranny tunnel. Mine was also a Bit(h to line up.
But once it's in there, it performs well.
Old Jul 12, 2005 | 08:05 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Inital install is a PITA and helps with a buddy to hold insert/hold bolts from up top so you can tighten the nuts. But on the street and at the track it works very well. Puts more hit in the tire instead of trying to lift the chasis up, if your running street tires and trying to hook them at a dragstrip with this torque arm, you will be out of luck, keep the stock unit or a longer levered torque arm for that job. If running more hp than stock and using stickies it's a great peice.
Old Jul 12, 2005 | 09:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't know, but do you think that the torque arm failed and broke the rear end housing?
Old Jul 13, 2005 | 05:45 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
No not at all. I think the cast casing and leaving on a 2 step set at 6200rpm did that. But the tq arm still failed. I did get 3 passes befor it died though.
Old Jul 13, 2005 | 06:48 AM
IHI's Avatar
IHI
You have a convertor in your car that allows you to 2 step at 6200??!! That's one loose son of a gun Betcha build all kinda of heat driving that loose goose.
Would like to hear the combination pf parts that allows the convertor to go that high, namaly cubic inches, small or big block, specs on cam, times you were running with that convertor. Your leaving all kinds of ET/mph on the table if that information is even remotely accurate.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Linson
Aug 21, 2015 02:12 PM
anesthes
Aug 8, 2015 09:37 PM
