Bump Steer Kit
Old 08-19-2005, 07:53 PM
Holio's Avatar
Car: 84 Z28
Engine: 305 L69
Bump Steer Kit
Does anyone know who else makes a kit for our cars other than Baer? I'd like to get the Baer kit but no one has it in stock, and can't get an answer out of Baer about availability.
Old 08-19-2005, 09:51 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
try this... It may work it is a bump steer item for circle track cars
http://www.speedwaymotors.com/xq/asp...splayGroup.htm
Old 08-20-2005, 06:38 AM
Holio's Avatar
Car: 84 Z28
Engine: 305 L69
Thanks SDIF, nice site, didn't know about them. Looks like you can build your own stuff and do it cheaper and better than Baer.
Old 08-20-2005, 09:05 PM
SDIF's Avatar
they are good for springs and weight jacks too.
very good prices and service
Old 05-19-2006, 05:05 AM
ABJ88's Avatar
Car: 1990 RS/2000 Z28
Engine: 5.0/5.7
Transmission: 4L60/4L60E
Axle/Gears: 10 bolt/3.23
Sorry I know this is an old post but I'm curious if anyone purchased the parts for the bump steer kit from speedwaymotors.com. I noticed you need to piece it out. Im interested in knowing what I need, they have different lengths and parts. Is it okay to use for daily driven car? I noticed circle track was thrown in there. Thanks!
Old 05-19-2006, 10:25 AM
2tone's Avatar
Bumpsteer kits are needed even for daily drivers as a critical steering correction device for a lowered car. The kit will allow you to correct the articulation swing of the tierod. You can see in my diagram below how the tierod geometry shortens and lengthens in lateral length as the suspension travels. You want the complete suspension travel arch to be close to centered on #2 with #1 a starting stagnant ride heilght and #3 a max suspension travel.
When a car is at stock height, the tierod arm will be at approx #1 position with a #3 max travel. When you lower a car, the standard position becomes more around #2 with a max travel and shortening of #4(not pictured, but you get the idea) and this will causeradiacl toein of that wheel underheavy suspension travel thus cause unwanted steer of that wheel when incurring a bump.
Old 05-19-2006, 05:12 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Try Ed Quay he say thay are only for off road use.
Old 05-25-2006, 01:01 AM
83 Crossfire TA's Avatar
Have you guys ever tried to measure your bump steer on a 3rd gen? GM did a very good job with them from the factory, especially compared to competing cars. You can usually lower them 2” without even needing to change toe settings because there is almost no bump steer across the whole useful range of the front suspension (assuming everything is right to start with), where if you look at something like some of the mustangs and other fox chassied cars you’ll find that lowering them about the same amount changes toe about 3/16-1/4”
Old 05-25-2006, 11:19 AM
Shagwell's Avatar
Car: projects.......
My sport lines changed my toe less than .1 - The Hunter 900 at the TK I used-to work at showed my settings to still be within factory specs.
Old 05-27-2006, 02:18 AM
ahhhFlubbernuts's Avatar
I'm lowered about 2 1/2" I would guess (24.75" at fender lip off the ground) and I can assure you my atriculation range shortened over 1/8" each side with factory tierods through the suspension travel.
Old 05-27-2006, 03:15 AM
Dean, I would suspect that there was something tweaked on your car or maybe your idler was mounted a little off. My ’83 sat right at 25” with 26.2” tall front tires and I didn’t have to change toe settings when I lowered it, and FWIW, the early 80’s cars started out sitting MUCH higher then the later 3rd gens, so if anyone should have seen a big change it would have been that car.
I’ve had exactly the same experience with my other 3rd gens, but none of them have been lowered as much as the ’83.
Old 05-27-2006, 03:23 AM
Car is an '87. I have owned it since '92. Wifes uncle was first owner and it has nevr been in an accident nor has ever even hit a curb or anything of the such. I would not even bother screwing with a car if it had ever been tweaked previously. It had bumpsteer and needed correction from the lowering. This car tracks flawless now, but was a noticiable problem before I corrected the geometry.
83 Crossfire TA
01-03-2016 01:26 PM
tonys91rs
10-10-2015 03:31 PM
SG91camaro
09-05-2015 10:27 PM
1Aauto
Sponsored Vendors
09-02-2015 01:50 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
Quick Reply: Bump Steer Kit
