Can't hook up when going full throttle.
Old Sep 1, 2005 | 07:46 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
Basically if I am not already moving at least 15 miles per hour, I cannot get any traction, even if I only give it half throttle. My tires spin and my tail swings out. THe only way to make it stick is to completely let off the throttle. If it makes a difference I have a ZZ1 crate motor, stock 700r4, 3.73's and some other performance stuff. And, the car has no suspension upgrades that I am aware of. Thanks a lot guys.
Old Sep 1, 2005 | 07:59 PM
JesasaurusRex's Avatar
slicks
Old Sep 1, 2005 | 08:01 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
And the problem is....... Just kidding man. But even a stock 305 can break the tires loose at WOT. your making alot more power than stock and its over powering the tires, you need either suspension mods or like most people would recommend bigger stickier tires, or both depending on how much you're looking to spend. Panard bar, lca's, lower control arm relocation brackets, sub frame connectors, and some big sticky tires and that thing will not come unhooked unless you're trying really hard.
Old Sep 1, 2005 | 08:20 PM
ZZ4 86 Z28's Avatar
well, my tires are new bf goodrich radial t/a's and the back ones are big. theyre like 275/65sr15 or 60 maybe. sorry about the repition from the other board.
Old Sep 1, 2005 | 10:56 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
I would deffinitly look at some LCAs and new LCA relocation brackets amung the other normal suspension mods.
Old Sep 1, 2005 | 11:35 PM
EvilCartman's Avatar
Car: '82 Z28
That's your whole problem right there... those tires don't hook worth a crap. They make great burnout tires though.
Old Sep 6, 2005 | 01:29 PM
ZZ4 86 Z28's Avatar
i might have found front and rear sway bars closeby...what will they do to help me. and also, the previous owner may have already put them in so how can i check for them. thanks a lot.
Old Sep 7, 2005 | 09:23 AM
BAD91CamaroRS's Avatar
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
Most likely your car has sway bars on it unless someone took them off. I second the statement on those tires being ****ty too.
Old Sep 8, 2005 | 12:34 AM
Car: '82 Z28
Forget about the swaybars, it's your tires. I borrowed a set a while back when my car had a 305 and it would spin them up no problem. Went back to my regular tires and could hardly get them to spin. Friend of mine runs those tires and the car gets all over the road when he presses down the go pedal.
Old Sep 8, 2005 | 05:42 AM
ZZ4 86 Z28's Avatar
interesting. they have a lot of tread too like 95% so i prob wouldnt have a problem selling them. plus i can change them out myself. thanks for the help.
Old Sep 8, 2005 | 11:55 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
I used to street race quite a bit, and never backed down from or got beat by ANY car running Radial T/As. Worst high performance tire you can buy, but they last a long time. The sidewalls will dryrot before the tread shows significant wear.
Usually, by the time a guy learns to make significant horsepower, he already knows this. Oh, that's right, it's a crate motor.
Old Sep 9, 2005 | 01:53 AM
83 Crossfire TA's Avatar
you can run 1.8 60's on them...
Old Sep 9, 2005 | 10:53 AM
Engine: tpi 305
1.80 60ft on radial T/As.....I'd have to see it to believe it, and right now I don't. Comp T/As on a light, well engineered platform....maaaybe.
We used to laugh our butts off at 'hot' cars with T/A radials. They might as well have POSER written on the sidewalls.
ZZ4 86 Z28, get rid of those tires as fast as you can. They're killing your credibility.
Old Sep 9, 2005 | 06:30 PM
ZZ4 86 Z28's Avatar
ok.
Old Sep 10, 2005 | 03:12 PM
OK, fine… Disclaimers:
- This was shot right after the car got in an accident that sheared off the nose forward of the core support (car was not moving in a parking lot at the time, long story)… no front end on it made the top end pretty hairy since above 85mph their was enough air getting packed under the nose that the hood was trying to lift off the hinges (as in it was coming up about 3” at the back) and the plastic body panes on the bottom were inflating and scraping the pavement. I don’t believe that I crossed the finish line on any run that day with my foot to the mat because of this
- My logs show that air temp was 98* and super humid at the time making everything slow
- Those tires are either some 235/60/15 BFG TA’s or some 215/65/15 Eagle GT+4 (the only tires that I’ve ever had on those rims), I don’t remember. From the video they look like the BFG’s since I know that those are the same size +4’s on the front and they look a little smaller then the rear tires. For the sake of this conversation it shouldn’t matter since the smaller +4’s offer much less traction then the TA’s
That being said:
better video, worse run
better run, but being in the far lane you can’t really see the launch well or hear the tires as well
In both cases I ran a low 1.8 60’ time, and this is basically a stock L98 with a cold air and cat back. Well, obviously with a little weight removed and worse aerodynamics.
Old Sep 10, 2005 | 03:18 PM
Old Sep 13, 2005 | 05:07 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Do the LCA relocation brackets cause tires to wear faster, thought that would be the case cause of the increased pressure to the tires. Then again w/ thirgen tires don't keep there tread very long
Old Sep 13, 2005 | 10:47 PM
No, the tires won't wear faster, and in most cases you won't have more traction with a street radial... My formula and TA don't have them and are both lowered and both have plenty of traction, my WS6 does have a set but I found that I actually ran slower 60' times with them with radials on the car so I'm back to the stock pivot points.
Stryker412
Sep 20, 2015 06:59 PM
banksGTA
Sep 13, 2015 11:56 AM
ericjon262
Sep 11, 2015 06:07 PM
Randomtask2
Sep 7, 2015 05:06 PM
SG91camaro
Sep 5, 2015 10:27 PM
