Tires.
Old Sep 19, 2005 | 10:31 PM
86MaroTPI's Avatar
Car: 1986 Camaro Z28
Tires.
Just curious. I am looking at buying new tires for my 86 Z28. The tires that are on it now are 215/65-15's, (stock i believe). I was looking on tirerack.com, and it said there, that 235/60/15's were optional equiptment. Just curious if my rims that now have the 215/65-15's will work with the 235/60/15 tires. Or would i need new rims for the wider tire?
Any help is appreciated
Old Sep 19, 2005 | 11:33 PM
Codename 47's Avatar
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Should fit fine. But someone else should confirm this.
-Greg
Old Sep 19, 2005 | 11:41 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
i went from 215/65r15 to 235/60r15 with no problem.
Old Sep 20, 2005 | 12:59 AM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
I'm driving on 235/60/15's with no problem. I might go a little wider next time.
Old Sep 20, 2005 | 01:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
they fit fine, look nicer too.
I run that size on the front, and 275/60 on the rear, but I have 8" wide wheels.
Old Sep 20, 2005 | 06:31 PM
85rocker's Avatar
I used 245/50 15s once. Comp T/As.
We couldn't get the weights to stick. The tire over hang interfered with the clip holding the weights.
We ended up using tape on weights on the inside but they used to fly off all the time.
Old Sep 20, 2005 | 08:56 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
speaking of tires, can anyone tell me the stock width of the 16 inch wheels...i think its 235 or 245?...also what was the widest stock tire for the 16" wheels?
Old Sep 20, 2005 | 10:35 PM
86MaroTPI's Avatar
Check on www.tirerack.com Do a vehical search.
Old Sep 21, 2005 | 02:44 PM
85rocker's Avatar
Factory 16 was
245/50 16
Factory 15 was
225/65 15
Old Sep 21, 2005 | 04:58 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Originally posted by 85rocker
Factory 16 was
245/50 16
Factory 15 was
225/65 15
Actually the factory 15" tire was 215/65/15 with an optional 235/60/15 when 15" wheels were the largest available.
Factory 16" was 245/50/16 on the Iroc/Z28 model, however base models with 16" wheels recieved 235/55/16.
I'd recommend 235/60/15 on 15" wheels.
Old Sep 21, 2005 | 06:05 PM
Car: 1988 SC Camaro
Engine: 305 TBI
over the 245/50/16?...why is that,? I'm just curious...i wanted to eventually upgrade to the stock 16 inch z28 wheels with the stock size or slightly larger tires (i have the stock 215/65/15 right now)
Old Sep 21, 2005 | 06:06 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Is there anything better about having the 215/65/15 instead of the 245/50/16?
Old Sep 21, 2005 | 06:17 PM
Car: 91 Camaro RS
Read carefully I said I recommend 235/60/15 on 15" wheels.
The only thing that 215/65/15 are better at than 245/50/16, besides price, is snow traction.
Old Sep 22, 2005 | 08:10 PM
Car: 1988 SC Camaro
Engine: 305 TBI
ok...but would you recommend 235 on 15s instead of 235 on 16s?, and if so, why?...I think I'd probably want to go with the 245/50/R16, since they were the biggest stock wheel/tire...I'd like to keep it stock or real close and i thought going from my 215/65/R15 to a 245/50/R16 would be a nice little upgrade, something not too drastic yet nicer looking
Old Sep 22, 2005 | 09:46 PM
Car: 91 Camaro RS
In about two weeks I'll be running 255/50/16. I would recommend either 245/50/16 or 255/50/16. I would recommend 16" wheels over 15" wheels. They have less sidewall and allow for larger brakes.
Old Sep 23, 2005 | 10:04 AM
86LG4T56's Avatar
Car: 1986 Firebird
Engine: LG4 305
I used to have one of the Camaro Berlinettas that came stock with 14" gold aluminum wheels. Dang they were ugly. Stock size was 205/70-14! That's just nasty.
87v6Bird
Jul 1, 2018 04:12 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
F-body-fan
Sep 17, 2015 12:16 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
