need help naming part so i can fix it...
Old Oct 20, 2005 | 07:54 PM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
it is between the tire and the shock. there's a bar that goes across the car and the part i need looks like a small shaft that goes upward and connects to another piece. it has a nut on each end and some washers on it...i'm sure it might be a ~bushing~ of some sort but when looking at the parts store there are a few different kind...also, i don't have one at all on the driver's side...should i be worried?...
Old Oct 20, 2005 | 07:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Swaybar endlink?
Old Oct 20, 2005 | 07:57 PM
TA_drag's Avatar
Car: 85 Trans Am
Transmission: t5
a sway bar link maybe
Old Oct 20, 2005 | 08:08 PM
Trah84Z's Avatar
Engine: 305 V8
safe to drive w/o it?...
Old Oct 20, 2005 | 08:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Safe enough, but the car won't corner so well.
Old Oct 20, 2005 | 08:12 PM
Trah84Z's Avatar
Engine: 305 V8
thank you...at least now i can drive it to work and fix it this weekend...
Old Oct 20, 2005 | 08:18 PM
Stevo's Avatar
Car: Pair of 92 Z28s
when my endlink broke the whole bar rattled like hell underneath the car...mainly over bumps side to side. Would make sence if only 1 side was mounted...
Old Oct 20, 2005 | 08:31 PM
Trah84Z's Avatar
Engine: 305 V8
so i should only have one side mounted?...
Old Oct 20, 2005 | 10:52 PM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
No both sides need to be mounted, imo I would also replace the other one if old.
Old Oct 20, 2005 | 11:22 PM
CaysE's Avatar
Get yourself two sets of these, 1 set for front and the other for rear. The page says "front endlinks" but are actually the correct size for front AND rear.
http://spohn.net/product.cfm?productid=1351
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
89GTAbird
Aug 9, 2015 12:40 AM
1nastygta
Aug 8, 2015 07:38 PM
