front coil spring install
Old Nov 6, 2005 | 07:12 PM
vinceanity92's Avatar
Car: 1992 rs
Engine: 305 tbi
how in the heck do i get my front coil spring back in the seemed pretty eager to get out, i have the outside style spring compressors but the springs streched them and cracked the hooks, i tryed to put spring into a log splitter and then wire it copressed but it just blew out the wire, what to do
Old Nov 6, 2005 | 09:28 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
get a spring compressor and put it inside the spring. make sure it sticks out of the hole in the a arm, and re assemble. it also helps to have the car higher off the ground to allow the a arm to swing down as far as necessary.
Old Nov 6, 2005 | 11:11 PM
CrazyHawaiian's Avatar
Car: too many ...
Last time I helped my friend do his front suspension we were able to do it without a spring compressor. Kind of supprised me too because I always thought you had to use one with the taller springs (14-12" tall uncompressed). But my friends dad knew the trick: Set the spring up into the k-member and attach a safety chain just in case, looping through the second or third from the top coil through the hole in the k-member (engine side). Then place the a-arm under the spring and angle it so you can start threading the balljoint nut through the spindle. Once you have that started tighten it up, but not all the way. Then place the floorjack under the a-arm and jack it up to compress the spring. If its seated properly it should stay put but the safety chain will be the backup just in case. Once the a-arm tabs get close to the k-member you can use a screwdriver to align them and get the bolts through. If you're jacking the a-arm up and the body lifts off the jackstands you need to place the jack closer to the inside of the a-arm. Just remember that this is one example of how I've done it, I'm not saying this is the best or only way to do it, and I'm no suspension expert or anything, just some guy. Hope it helps.
Old Nov 7, 2005 | 12:52 AM
83 Crossfire TA's Avatar
I don’t know how many times I’ve posted this, but you’re doing it from the wrong side.
Let the arm pivot on the ball joint and put the spring in from the pivot bolt side and jack that side up, it’s much easier that way.
Old Nov 7, 2005 | 01:36 AM
Car: too many ...
Isn't that what I just said? Or am I going crazy?
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
TheExaminer
Aug 25, 2015 07:34 PM
TA8487
Aug 11, 2015 09:02 PM
