Which Sway Bars?
Old Dec 12, 2005 | 08:51 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Which Sway Bars?
I'm looking to replace the swaybars and bushings on my car. And im curious as to what size i should get. My car has Eibach Pro Kit springs, Bilstien Struts/shocks, wonderbar, Spohn SFC's, Spohn LCA's and LCA Relocation Brackets. What size would give my car a neutral-to-oversteer condition?
Would these Spohn pieces bee good?
http://www.spohn.net/product.cfm?productid=1311
Or how about these Hotchkis, the front is larger but hollow
http://www.jegs.com/webapp/wcs/store...0079&langId=-1
Old Dec 13, 2005 | 06:53 AM
92MaroRS's Avatar
anyone?
Old Dec 13, 2005 | 08:17 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I'm a big believer in Spohn Products.
And the kit you linked says it's for the 4th gen.
Well the Spohn Desc says: "provide predictable handling (matched sizing for balanced handling)."
If you wanted to save a little $ and not get as much handling WS6 bars would be a good starting point. They can usually be snagged at a JY pretty cheap. Send them off to the local powdercoater or ship them somewhere. And no one would probably know they were OEM pieces looking at them.
Pick up a bolt kit too. I put a wonderbar on my car and it took me several days soaking the bolts to break loose. I was really afraid I would break them.
Old Dec 13, 2005 | 02:31 PM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
What wonderbar do you have?
The spohn swaybars don't seem to fit GM wonderbar's and I suspect they won't fit TDS wonderbars.
They also don't seem to fit 85 irocs....
Si.
ps. Not quite sure what they do fit!
Old Dec 13, 2005 | 04:48 PM
92MaroRS's Avatar
Si.
i have the TDS wonderbar.
Old Dec 13, 2005 | 05:05 PM
iroc-si's Avatar
Well then you cannot use the Spohn swaybars. They will probably collide. The problem is the portion of the swaybar that runs parallel with the wonderbar. The spohn bar bends forward further than the stock bars. The spohn wonderbar allows this, but causes problems with the fans, especially on dual fan systems.
I'll attach a few pics of the problems with a standard GM wonderbar. comparing a spohn swaybar with an iroc swaybar.
Si.
iroc-si's Avatar
now the problem in detail
Old Dec 13, 2005 | 05:07 PM
iroc-si's Avatar
now here's another problem with the spohn bars.... they're too wide to fit properly on a camaro!
Here's the width comparison with an iroc bar. The difference is 1.75".
Si.
Old Dec 13, 2005 | 10:51 PM
92MaroRS's Avatar
nothing a little grinder action wont fix.
Old Dec 14, 2005 | 05:06 AM
iroc-si's Avatar
Sure, that bit can be dealt with by grinder, or spacer plates, if you're desparate to use a Spohn part.
The bit that made them useless was the width. The endlinks could be made to connect in, with a bit of hassle, but when you turn the steering from lock to lock it bashes the bar from one side to the other with the base of the strut. This is not a good idea.
Overall, you would be better getting a swaybar from another source to avoid these problems.
Si.
ps. Please don't be one of the fools that replied originally saying they don't use full lock so it'll be ok....
Old Dec 14, 2005 | 09:42 AM
92MaroRS's Avatar
Si.
Well I've had really good luck with parts from Spohn and the customer service is great. they might have changed their part or you might have gotten a bad part, ill probably end up giving them a shot at it with me anyway.
Old Dec 14, 2005 | 12:10 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The GW Steering Brace does use a larger diameter center bar, but it's design also puts that center bar farther forward, so I'm not surprised it will fit the Spohn sway bar. I sell the TDS e/t Improver Plates which are aluminum spacers. Using two sets of these between the brace and sway bar mounting brackets will solve the interference problem with that sway bar and either the GM or TDS Steering Brace.
Lon
Old Dec 14, 2005 | 09:47 PM
sixtyV6's Avatar
EDE is a piece of sh*t
Ban me asswipe if you don't like my helpful post.
You are only antogonising me to cause trouble
I plan to have alot of fun around here durring the holidays
Merry fu*ken X-mas
Old Dec 14, 2005 | 10:01 PM
92MaroRS's Avatar
Merry fu*ken X-mas
anyone care to share why his post was deleted? it was very helpful.
Old Dec 14, 2005 | 10:34 PM
lonsal's Avatar
Yeah I can. Some of the Moderators are dead-set to delete any post of Deans because they continually ban him and he pops up again. IMO leave his helpful posts, but I'm in the minority it appears.
Lon
Old Dec 15, 2005 | 07:01 AM
92MaroRS's Avatar
Lon
guess i am too, helpful info is helpful info, even if it may come from a not so great member. oh well, atleast i got to read it before it was deleted.
Old Dec 15, 2005 | 07:39 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
What did it say?
Old Dec 15, 2005 | 09:52 AM
92MaroRS's Avatar
Originally posted by gmgod
What did it say?
that iroc-si's car is probably tweaked since no one else has ever had a problem mounting up spohn sway bars, other than the interference with the wonder bar, which like i said, can be fixed easy enough with a grider.
Old Dec 16, 2005 | 04:39 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Will the Spohn Wonder bar works w/ Stock Front Sway bar?
Old Dec 16, 2005 | 04:57 PM
92MaroRS's Avatar
Yes, but i have heard that numerous people have has to 'elongate' the mounting hols.
Old Dec 17, 2005 | 05:37 AM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
My rear sway bar from spohn actually has rubbing issues against my left rear shock....noticed it when I put the car up on jacks for the winter...kinda worries me because there's really no play to shift to the other side
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
