Tubular front end
Old Jan 5, 2006 | 01:13 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
Tubular front end
I saw a brief message about a tubular K member by PA that was criticized harshly. Spohn seems to be a reputable company though. Has anyone heard of other "good" companies that might have a similar product? I'm looking to lighten the load up front. Thanks Daniel GN3 FBDY
Old Jan 5, 2006 | 01:16 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'm running an AJE racing setup.
Old Jan 5, 2006 | 06:31 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
BMR, But I am waiting for spohns. Should be out soon. (I hope)
Old Jan 6, 2006 | 01:17 AM
CrazyHawaiian's Avatar
Car: too many ...
I recently found out that you might not save as much weight as you think. I dont remember exactly where but I read on some website selling the stuff for our car that a tubular front end will drop between 50-75 pounds off the front. When we had a thread on these forums with factual information on stock k-member versus the aftermarket tubular stuff, there was not a significant weight difference. Not enough in my own personal opinion to justify the cost of the aftermarket stuff. Definately no 50-75 pounds. I would recommend you search for that thread and see the actual weights before dropping your $$.
Old Jan 6, 2006 | 02:08 AM
xpndbl3's Avatar
Car: 1984 Z28
i think it's worth it for the ability to drop the oil pan without pulling the motor and header clearance alone.
Old Jan 6, 2006 | 02:42 AM
Car: too many ...
I agree and I'm not trying to take anything away from them except that some people might be under the impression there is a huge weight saving (like I was). It would suck to drop all that $$ to drop weight and then find out the weight savings are minimal when you get the product in your hand.
Old Jan 6, 2006 | 04:09 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I think I rememebr seeing pictures of the AJE unit and it looked better than any of the other out on the market. Do you have pictures of yours you can post?
Old Jan 6, 2006 | 09:25 PM
xpndbl3's Avatar
Car: 1984 Z28
there are a bunch of pictures on the AJE racing website if you'd like to check them out. My car is in storage until spring and won't be able to get any shots of it until then.
Old Jan 10, 2006 | 11:20 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I don't yet have the tubular k-member, but I am waiting on Spohn's. I am getting it and the tubular a-arms for two reasons.
One is it will help me run the AC on the LT1 (which I plan to have in soon...) with out modding anything.
Two is, with the full tubular front, I will cut a respectable amount of weight (in addition to the aluminum heads) for the front, which I hope helps with the car's cornering.
The Spohn should be our soon, from what I hear.
Old Jan 11, 2006 | 02:12 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I've never found any. I'm probably blind though. I saw one of the fourthgen and that was it.
http://www.ajeracing.com/camaro.htm
Old Jan 11, 2006 | 07:35 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
XPNDBL3
Hey why does your f body look so fat.
Mean that in a good way..
Looks like an fbody on on steroids.
If you put some louvers on it would look even fatter
Old Jan 15, 2006 | 07:10 PM
Kandied91z's Avatar
Re: Tubular front end
do it for space, not weight.
Old Jan 16, 2006 | 05:51 PM
Shagwell's Avatar
Car: projects.......
Old Jan 20, 2006 | 02:51 PM
zrotten's Avatar
weight only counts if.....
You will lose a lot of weight if you go the whole way and switch to a rack and pinion steering. If you look at the whole picture:
k-member
stock coils
stock arms
steering gearbox
all steering linkage(tie rods ,centerlink., pitman..)
all brackets and bracing
stock spindles.
I installed a PROFAB setup with QA1 coil overs with lakewood 90/10 struts and light weight spindles.
I lost 160 pounds. If you drag racing and thats the reason for weight and you have the money-DO IT , if not the only reason I would do it to my street car is for header cleareance and oil pan removal.
Later
Rotten
Old Jan 20, 2006 | 02:59 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Re: Tubular front end
i was going to say the same thing.
the stock Kmember is not that heavy.
the tubular A arms together dont save one lb compared to the stock ones.
if the goal is weightloss, your money is better spent elsewhere.
if the goal is space underhood, then its something to consider.
Old Jan 20, 2006 | 03:06 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Since I just rebuilt my A arms 2 years ago with poly bushings, poly stops and new Moog joints. I will be reusing those with the spohn K member. Plus If I need to I can place a jack under the a arm too.
Old Jan 20, 2006 | 03:19 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
not a bad idea since the two other Kmember and A arm companies (profab and PAracing) sometimes do stupid things... like make the A arms diffrent lengths by accident... or have the mounting tabs in the wrong area/position for the A arms... it'll all go together since thats teh way the jig is, but it wont work correctly.........
plus with either of them, you HAVE to use tubular a arms... you cant run the stockers.
Old Jan 20, 2006 | 03:50 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Say u run tubed K and arms, how do you go about jacking i tup like we used to by placing the jack under the old k member? Will the new k member have a provision for this, will it be strong enough? If I have my car on jacks under the subframe. how the hell would I get the car off If i can place a jack anywhere up front anymore>?
Old Jan 20, 2006 | 03:53 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
not once in my life have i jacked my camaro off the front Kmember..... its always been too low, and the jack would be too far in..
i always use the "convertible bracing" on my car.... same location as good SFCs if you have them.... otherwise, the jack has to go on the "frame rails" near the transmission next to the front tires.
Old Jan 20, 2006 | 07:31 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i run a pa crossmember and im not very impressed. very poor quality. my one tie rod is rubbing the crossmember. im waiting for spohn to release his and ill get his. i have his A-arms and they are top notch quality. very nice product.
Old Jan 20, 2006 | 08:03 PM
Kandied91z's Avatar
i've been waiting since i joined this site, got tired of waiting and haven't looked back. i have considered changing to spring perches again for the sake of offset space for the wheels but i'll have to wait and see.
as far as jacking the car up it can be a headache because of this yes. i've jacked the car up once using the tubular k member in an emergency and haven't done it again for fear of issues. who knows though..
Old Jan 21, 2006 | 02:03 PM
zrotten's Avatar
Use the K-member to jack the car up is ok if you FAB up a half round piece of plastic(thick and hard) or what I use is a half of a polyurethane bushing mounted to a piece that sits in the top of my cup (Craftsman Jack) Nothing special.
Later
Rotten
Old Jan 21, 2006 | 03:51 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
The jack I use is my Dad's Napa. It is NICE. Has a padded handle to avoid body damage. And the lift point is a very thick plastic pad attached to where the metal cup usually is.
I plan to get the Spohn K-member for one reason. The LT1 clearance. I don't want to have to change the AC or modify the stock K-member. The K-member would be nice.
Old Jan 23, 2006 | 07:46 PM
zz4z28's Avatar
I have the pro fab with rack and pinion, and I lift it off the k-member all the time, the hard part is getting it centered so it doesn't lean one way or the other, but I have never had any problems with it.
It is for sale to if you are interested!
mwrighttt@aol.com
Old Jan 23, 2006 | 07:54 PM
zz4z28's Avatar
mwrighttt@aol.com
Old Jan 23, 2006 | 09:08 PM
Shagwell's Avatar
another thing for the weight savings(k member or otherwise) Chris Alston's list the "Vari-shock" front struts for our cars. Aluminum bodied, even available threaded for coil-overs. - Not huge weight, but I'm going for broke. 4161 lbs....SUCKS!!!! byebye uni-body structure, hello 2x3 frame and coil-overs....
Old Jan 23, 2006 | 09:18 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
4161? What weighs that much?
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Your GTA wiegs more than 4klbs???GN3 FBDY
Old Jan 23, 2006 | 09:19 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I was thinking 3200-3400
Old Jan 24, 2006 | 11:45 AM
Shagwell's Avatar
me(162 lbs at the time) huge stereo, roll-bar, in floor frame, a/c, and all GTA options w/ the rag top + a little under 1/2 tank = 4161...
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bellez77
Sep 5, 2015 08:39 PM
