Sub-Frame Connectors?
Old Jan 26, 2006 | 09:14 PM
formuladb's Avatar
I have an 1989 formula 350 and want to add bolt on subframe connectors. I and looking at several different brands including
S and W race cars, Competition Engineering, and Jegs even has their own brand. The S and W look great but are $350 the other two don't look quiet as good but cost alot less. I am open to any other suggestions to.
Old Jan 26, 2006 | 09:35 PM
blkdrgn71's Avatar
Car: 1989 Firebird
Engine: 406
Transmission: 700r4 / 3000 stall
UMI sub frame connectors 159.99 plus shipping. look in the group purchase board. I ordered a set.
Tim
Old Jan 27, 2006 | 12:17 AM
irocstang's Avatar
Car: 86 IROC
Engine: 5.0
Transmission: 5 speed
bolt on sfcs
i would reccomend going against bolt ons as you will have problems down the line like bolts coming loose, not to mention the holes where the bolts go through will get bigger too. Nothing but problems with bolt ons. Do it right the first time and weld them in....and you shall have no problems.
Check out the umi ones thats what i ordered.
Old Jan 27, 2006 | 01:53 AM
miamivice's Avatar
Car: 88 GTA
Re: bolt on sfcs
what he said
Old Jan 27, 2006 | 05:29 AM
ede's Avatar
ede
Old Jan 27, 2006 | 07:53 AM
formuladb's Avatar
That is some great info about not using bolt on subframe connector. Does anyone know how much it cost to get them weld on. I don't have the equipment.
Old Jan 27, 2006 | 08:27 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I stripped out my carpet and took mine to a local exahust shop and paid $75. The only thing they didn't do is paint over the welds to keep it from rusting, I did that myself.
Old Jan 28, 2006 | 08:18 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
Whatever you do....make sure when whoever welds them up that it is done on a lift that you drive up on. ALL 4 WHEELS HAVE TO BE ON GROUND TO WELD THEM PROPERLY. Not the kind of lift that picks you car up from the sides like this < >
Old Jan 28, 2006 | 08:52 PM
Dracul's Avatar
Car: 1983 Camaro z28
Engine: 5.7
Transmission: 5spd
why do you need the drive on lift? the shop i was gonna go to just has the side lift.
Old Jan 28, 2006 | 09:47 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Loads the suspension with the weight of the car.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
