asking the experts....pro kit rake prob
Old Feb 6, 2006 | 10:17 AM
black88cam's Avatar
Car: 88 Camaro
Engine: Modified 350
Transmission: B&M 700r4
I have done alot of search's on the pro kit the most recent people have been saying the have a rake prob low front and high rear.. I want to lower my car about a 1" on all corners..Thru the early part of the searches people were Recommending this kit but lately posts have said otherwise..So I have a few questions does the cars without the rake have the hatch full of stereo equ. causing the weight from the box and amps..batt ect. to hide the rake prob..I need some pics posted with the pro kit and if there is any weight in the rear of the car...Thax Jason
Some Pic's
Old Feb 6, 2006 | 10:18 AM
black88cam's Avatar
Car: 88 Camaro
2nd
black88cam's Avatar
Car: 88 Camaro
last
Old Feb 6, 2006 | 10:58 AM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Sorry, I can't offer any pics. I just wanted to say that you have a great looking car. Keep up the good work.
Old Feb 6, 2006 | 11:52 AM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
No picture i can post at the moment, but mine sits level, i hate it, i want my rake back, gonna put new rear spring mounts in and that should put it right where i want it. I do have 2 L5 solo baric's and a 800.4 and 1200.1 amp in the back.
Old Feb 6, 2006 | 01:02 PM
CrazyHawaiian's Avatar
Car: too many ...
In my opinion there is no universal answer on this one. Because part of it is a personal preferance (where one persons idea of a bad rake is different than yours) and the other thing is that not everyone runs the same tire setup and that makes a difference as far as the look. The Pro-Kit is advertised to drop the car 1" front and rear. IMO the Sportline is the kit that will give you what I consider an odd rake. But again its all personal preferance from what I've already gone through. If you need ultimate control of the ride height look into Weight Jacks. The only downside of those is you probably wont find progressive rate springs short enough. Downside for some, no problem to others.
Old Feb 6, 2006 | 02:32 PM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
No rake problem with the ProKit here. The car stis nice and level, without a system. The back of your car will sit at least a 1/2 inch too high in back though if the springs are not seated properly in the pucks.
Old Feb 6, 2006 | 04:15 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
my car sat level till i found out that the 4th gen LS1 WS6 cars had a taller rubber puck for the rear spring to sit in
bout a half inch i think...
Old Feb 6, 2006 | 09:33 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
Prokit installed properly in the isolators and nothing in the back as far as weight. Sits too high for my liking, but doesnt bother me enough to cut or buy something else, until I opt for airride (the performance is awesome so why change it?)
Old Feb 6, 2006 | 09:39 PM
Gr89RS's Avatar
Car: '02 Z06
My RS was the same.
I would opt for more of a drop than the pro-kit though with that car. 2" or more would look hot on that thing. Good luck bubble-boy.
Old Feb 6, 2006 | 11:05 PM
I'd check the placement of your fronts for sure though, look at the difference between yours and mine
Old Feb 7, 2006 | 03:12 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Mine has a prokit and it sits level.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
customblackbird
Oct 1, 2015 04:30 PM
gta_knight
Sep 23, 2015 04:59 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
