Shop can't do alignment because of bad strut mounts?
Old Feb 13, 2006 | 06:46 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
The shop I have my car at said they can't do an alignment because my car has bad strut mounts. Regardless if the mounts are bad or not, is that true or BS?
How much are strut mounts and how hard are they to put in? Do new mounts come with new struts? I would like to replace the struts and springs w/i the next 6 months, buuuuuuut I don't want my front right tire losing any more tread. It's bald enough as it is. A slight camber problem it has.
Old Feb 13, 2006 | 07:24 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If the strut mounts are bad, they won't be able to do an alignment. You can inspect them by removing the dust cap. Get them to show you.
Strut mounts are about $75.00 each from your neighborhood auto parts place. Specialty mounts can be had for much more.
If the shop replaces them expect them to charge more that $75. You can replace them yourself then take it back for an alignment if you want to save a little cash. Only four bolts on each, but the large strut bolt can be a pain to get off if you don't have an air wrench.
When you replace struts and springs in a few months you should really get a new alignment then, too.
Old Feb 13, 2006 | 07:25 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
I wouldn't know how to tell you if that is bs unless you post a picture of them or the exact wording of what the mechanic said. I can tell you that you can buy new strut mounts, I believe spohn (sponsor above) sell some that are better than stock. I have yet to see a strut mount come with struts as a packaged deal. More than likely you will have to buy them separately. You do not have to buy new strut mounts to change the struts and springs. If they are really shot then you should replace them. I live in the rust belt, and have yet to see some worn out strut mounts on camaros and firebirds. This doesn't mean they don't exsit, I just haven't seen them. Post a picture of them if you could, then we can try to help you out a little more.
Old Feb 13, 2006 | 08:43 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
they could do one, but it wouldnt be accurate at all. Soon as you kick the tire it would be off.
If you need a set, give me a PM. I have a spare set.
Old Feb 13, 2006 | 11:19 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Replace them.
Whether good used ones or new ones.
They are correct in what they said, yours must be roaylly shot lol
They make some noise/grind/squeal?
later
Jeremy
Old Feb 13, 2006 | 11:39 PM
Car: 1994 Trans Am
I haven't heard any noises. But will new mounts improve shock absorbtion and handling?
Old Feb 14, 2006 | 05:46 AM
Dale's Avatar
Engine: 350 S-TPI
More then likely. I would depend on how shot they are as to how much difference you would notice.
Old Feb 14, 2006 | 10:33 AM
naf's Avatar
naf
The mounts usually fail when the "rubber" bearing support inside begins to tear. When it fails, the mount is unable to keep the top of the strut properly positioned. This introduces slack at the primary point of adjustment. Continuing to drive with worn mounts will only allow them to become worse and possibly allow the strut bolt bearing to separate completely from the mount.
Remove the dust cap and you can see what I'm talking about.
Old Feb 14, 2006 | 11:18 AM
Car: 1994 Trans Am
That cone is the dust cover, right? Just squeeze and twist off? Will it be noticeably worn if shot?
This is what needs to be replaced, correct? I don't need the actual bracket or anything.
http://store.summitracing.com/defaul...1&autoview=sku
Old Feb 14, 2006 | 12:19 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
These are the ones here:
Spohn Strut Mounts
Old Feb 14, 2006 | 12:24 PM
naf's Avatar
naf
The Spohn one's will run you a little more and may be heavier duty, but the KYB's will work fine. The photo on the summit site is representative only and doesn't look like yours will, they will include the "bracket". Try Tirerack for a better photo of the KYB mount. About the same price as summit, shipping will be the diff.
Old Feb 14, 2006 | 01:04 PM
Car: 1994 Trans Am
Could these bad mounts also cause vibration at around 85mph or so?
I've been battling that for quite some time now. Tire balancing didn't help. Those Spohn ones look nice.
Old Feb 14, 2006 | 02:28 PM
naf's Avatar
naf
They could possibly cause a vibration, but no promises.
How much did the shop want to replace the the mounts?
Frozer!!!
Jan 19, 2024 04:55 PM
g.l.mos
Aug 22, 2015 12:02 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
383backinblack
Aug 15, 2015 06:36 PM
