front end higher than rear
Old Mar 26, 2006 | 06:36 PM
Unholy 89's Avatar
Car: '89 5spd GTA
Engine: 305(LB9) TPI
Axle/Gears: Borg-Warner 3.42
I've been fighting this for sometime now and need some advice, I have new shocks on the rear and the front still sets higher than the rear. Also, when I'm driving and mash the gas, the front raises way up. Would new urethane bushings all around make any difference? Eventually I'd like to lower the car all way around maybe an inch or inch and 1/2.
Old Mar 28, 2006 | 01:14 PM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
new springs should help
First off my understanding is that shocks do not have anything to do with the height of your car, shocks only control the bounce. If you replaced your rear only and your car lift up from the front when you mash on the gas it's obvious your front struts are in bad need of replacement. Also I don't think bushing are going to solve your problem but they are a good idea to have to stiffen up the suspension. I just put a set of Prokits on my camaro and KYB shocks/struts all around and it's working great for me. Check this thread
https://www.thirdgen.org/forums/suspension-chassis/352168-eibach-prokit-install-so.html
Old Mar 28, 2006 | 01:21 PM
Unholy 89's Avatar
Car: '89 5spd GTA
Danke
Yep thats what I'll check into.
Old Mar 28, 2006 | 05:19 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Height determined by springs - shocks damper the bounce of the springs.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
bellez77
Sep 5, 2015 08:39 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
