Suspension
Old Apr 18, 2006 | 07:52 PM
circuit rider's Avatar
Car: 1986 IROC
Engine: 305 4bl.
Transmission: 5 sp. stick
Suspension
Have 86 IROC. Handles great, feels tight but has a very ruff ride. Good highway driving, Good tire wear, but on regular roads I feel every crack in the road. Some hard knocks. Is this normal? Thanks
Old Apr 18, 2006 | 08:13 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Feeling bumps in road is normal.
Knocking is not. Where is it coming from? Front, rear, left, right, under center of car?
Old Apr 19, 2006 | 07:24 PM
Car: 1986 IROC
Engine: 305 4bl.
Suspension
It comes from the front of the car. Front Struts are good. Very Tight. Thank you for your response.
Old Apr 20, 2006 | 09:51 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Check the front upper strut mounts. Even if all else appears normal the bearing may be the culprit.
Old Apr 20, 2006 | 11:57 AM
Dale's Avatar
Engine: 350 S-TPI
knocks up front can be quite a few things.
Strut hitting inner fender
ball joint
spring sitting wrong
upper strut mount ripped
bad strut
swaybar mount/endlinks bad
something loose.
May not even be suspension, it could be something else loose wiggling around.
Old Apr 22, 2006 | 09:11 AM
Car: 1986 IROC
Engine: 305 4bl.
Thank you for the replys. To be more exact it feels as though its bottoming out. Thanks, EJ
Old Apr 22, 2006 | 02:19 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
if it feels like its bottoming out, it may be in your best interest to take a look at your bumpstops. If they're damaged or non existant, you could possibly be bottoming out your struts and doing damage to them.
Old May 1, 2006 | 06:35 PM
Car: 1986 IROC
Engine: 305 4bl.
Very Possible. Thanks.
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
