whats wrong with this picutre...
Old Apr 29, 2006 | 03:12 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
i put sportlines in the car, and now the front is lifted up quite a bit
Old Apr 29, 2006 | 03:19 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Either you left the jackstands under the car or didn't index the springs properly.
Old Apr 29, 2006 | 03:23 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Look almost like there isnt a motor in there!! Did you compare the new springs to the old springs when you took them out?
Old Apr 29, 2006 | 03:26 PM
Car: 91 formula
Transmission: t5
yea the eibachs were a good size smaller to... can they just not be in the spring pocket right ?
Old Apr 29, 2006 | 03:28 PM
92MaroRS's Avatar
That has to be it, my PRO KIT, sits about 3 inches lower than that! LOL
Car: 91 formula
Transmission: t5
how the hell is there more then one way to put them up in the pocket tho, i just put them on the control arm and jacked it back up..
Old Apr 29, 2006 | 03:29 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
You should be able to look at the springs and see if they arent in the right spot.
Old Apr 29, 2006 | 03:30 PM
92MaroRS's Avatar
There are indentations that the spring fits into on the control arm. if you don't get it in the right place you can get the 4x4 look.
Car: 91 formula
Transmission: t5
i see, well time go rip it apart again i guess lol, fun
Old Apr 29, 2006 | 09:39 PM
boussole's Avatar
Car: 91 ws6
Engine: ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
Transmission: TRANSMISSION, MAN 5 SPD, B0RG WARNE
Axle/Gears: AXLE REAR, 3.42 RATIO
GM 1LE (WS6) springs are 360 lb/in for the front and 130 - 170 lbs/in progressive for the rear. to strogn for all
Old Apr 29, 2006 | 10:51 PM
Stevo's Avatar
Car: Pair of 92 Z28s
drive it around first, they might actually "pop" into place. I drove my car around after i was done big POP sound, i guess it was the spring adjusting itselt. Anyway my springs are not perfectly indexed between the holes, but they both sit equal about an inch lower(front). I have pro-kit.
Old Apr 30, 2006 | 11:12 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
This might help, Ed Miller has some good pictures of where the indexing holes are in the A-arms for the front springs. Scroll about halfway down the page to see them:
Yahoo! Photos - taramiller72's Photos - 88 Camaro Rebuild
Old May 1, 2006 | 04:46 PM
vindoo's Avatar
Car: 89 Formula 350
Thats definitely good to lnow and something I would have never thought of....
Old May 2, 2006 | 01:43 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
You sure on that front spring rate?
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
