Strut Tower Brace Without Drilling Holes?
Old May 3, 2006 | 11:04 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
I've been wanting to put a strut tower brace in my car for a while, but I don't like the idea of drilling holes in the strut towers. Would there be anything wrong with making one that would mount to the tower using 1 or 2 of the upper strut mounting nuts? Would it still be just as effective? Would it cause problems with the struts?
Thanks for your help.
Old May 3, 2006 | 11:34 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I drilled mine not once but twice, after I got a bigger air cleaner I had to move the brace. As long as you protect the holes you drill you will be OK.
Old May 4, 2006 | 03:47 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Here's how mine is. It was made by MRZ28HO off the socal board.
Old May 4, 2006 | 04:42 AM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Do you have the Edelbrock 3 point strut tower brace that was designed for TBI/Carb cars? If so, can you post a pic of what it looks like. I still haven't seen one yet.
Old May 4, 2006 | 11:12 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Is MrZ28HO still fabbing them?
JamesC
Old May 4, 2006 | 03:17 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
JamesC
I'm also curious. Any pics of the whole thing?
Old May 4, 2006 | 03:57 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
I purchased a MAC 2 pt stb from Lmperformance which required no drilling. The bar did the job of eliminating cowl shake as much as my 3pt edelbrock, however it took forever to be shipped in, and I would reccomend going another route unless you are unsuccessful in sourcing another non-drill stb.
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
JamesC
Nope. He's sold his ThirdGens and moved on to FourthGens a long time ago.
Lon
Old May 5, 2006 | 06:19 AM
JamesC's Avatar
Ok, Lon, it's up to you. Sounds like a to me. I'll even volunteer to be your test mule.
JamesC
Old May 5, 2006 | 08:33 AM
lonsal's Avatar
Cool, I'll schedule some time to work on it. Let me know when you can drop off your car.
Lon
Old May 5, 2006 | 08:40 AM
JamesC's Avatar
The drive back and forth from mid-Kansas should be fun
JamesC
Old May 5, 2006 | 04:06 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
It looks like Hawks carries the Mac STB also.
Hawks Third Gen Parts 82-92 MAC Performance Strut Tower Brace
Does anyne know if this STB fits Carb/TBI cars?
Old May 5, 2006 | 06:35 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I have no idea if it was made or bought, I bought the car with it.
[IMG][/IMG]
Old May 5, 2006 | 07:36 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
it would definitly come in contact with a factory or open element air cleaner.. although running a carb hat could probably be a solution.
Old May 6, 2006 | 07:00 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
So it works by using the already existing bolt holes ? No problem at all ?
Old May 8, 2006 | 02:35 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
it mounts to the front two studs of the upper strut mount. you simply remove the nuts as if to adjust your camber, slide the bar onto the studs, then tighten. Yes, it works.. stopped the cowl shake in my dad's 91 t/a
Old May 8, 2006 | 02:37 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
cowl shake?
Old May 8, 2006 | 08:34 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
Term used to describe the creaking noise caused by front end flex. It sounds like its coming from behind your dash.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
91chevyz28
Feb 10, 2022 07:58 PM
Antips16
Oct 30, 2015 06:42 PM
Fox118
Sep 12, 2015 09:29 PM
Ian Irvine
Sep 4, 2015 08:08 AM
