Rear dr side wheel popping
Old May 30, 2006 | 10:49 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
When I am coming to a stop I can hear and feel a popping sound coming from my dr side rear wheel.It almost sounds like pop corn, speratic popping.It does it around left hand turns or coming to a stop.I just replaced the calipers and pads and am wondering if it could be the bearings.There is no odd play in the wheel other than the usual in and out movement.It feels like it's binding a bit.It did it with the old brakes too.
Old May 31, 2006 | 04:20 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Once it started doing it today I stopped opened the door and slowly let off the brake to see what it was doing and I could see the wheel "pop" when it made the noise.
Old May 31, 2006 | 04:35 PM
ABJ88's Avatar
Car: 1990 RS/2000 Z28
Engine: 5.0/5.7
Transmission: 4L60/4L60E
Axle/Gears: 10 bolt/3.23
WTF. At first I thought I had the same problem, but mine sqeals. When I make long wide turns, like offramps or onramps(well here in C.A.)
Old May 31, 2006 | 10:13 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
It's getting bad. I'm gonna take the diff cover off and inspect the axles, carrier, and wheel bearings on friday.I just bought this rear and I've already had to replace the calipers so I hope it doesn't need a rebuild.
Old May 31, 2006 | 11:48 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
yowza. Yea, jack up the rear and grab the back left tire and pull it outwards, push it in, spin etc, see what you find out. Then pop off the cover and verify. Maybe the cross pin is gone...?
Old Jun 1, 2006 | 06:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Wheel bearing?
JamesC
Old Jun 1, 2006 | 10:10 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
I've jacked it up and moved the wheel and it just moves in and out by hand which I've read is normal.My guess is that it's bad but I just can't get it to move by hand.I'm inspecting tomorrow.
Old Jun 6, 2006 | 05:59 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
The lady that bought my old 87 said that it started doing the same thing after she bought it and it was the wheel bearing so hopefully that's it.I have to do it this week as I couldn't get to it last week.
Old Jun 6, 2006 | 09:37 PM
Stevo's Avatar
Car: Pair of 92 Z28s
is it more a poping or a clicking? I have a clicking when i hit the brakes...
Vintageracer
Jan 10, 2020 05:33 PM
kah992
Aug 19, 2015 02:55 PM
BlackBoulder
Aug 11, 2015 11:15 PM
wruiz
Aug 11, 2015 02:59 PM
novaderrik
Aug 10, 2015 12:44 PM
