How important is the strut cover?
Old Jun 5, 2006 | 03:57 PM
MJH91RS's Avatar
Car: 91Camaro RS
Engine: 305TBI
Transmission: 5-Speed
Axle/Gears: 3.08
As stated above, how important do you think that plastic cover is that protects the exposed shaft on the strut?
The stock one broke and will not work anymore. The Chevy dealership does not carry them, AutoZone doesnt have them either.
Is it worth the trouble to go to a junkyard and go through the trouble of taking off a strut for this little part?
Old Jun 5, 2006 | 04:17 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
I could be wrong but i dont think you have to take the strut out to put the cover on.I just got some off e bay for like $5.00 shipped.I guess im fixing to find out if you have to remove the struts to put them on.the only reason i could see to put them on would be to keep moisture and dirt out,but i dont think its mandontory.i just did it to clean up engine bay and look original
Old Jun 5, 2006 | 07:50 PM
MJH91RS's Avatar
Car: 91Camaro RS
Engine: 305TBI
Axle/Gears: 3.08
I'm talking about the one behind the wheel in the wheel well. It slides on top of the strut when you install it.
Old Jun 5, 2006 | 08:03 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I would recommend replacing it. Alot of dirt and grime can get kicked up onto that shaft and it slides up and down. You don't want the seal on it getting torn up or the shaft nicked by a rock. You can just get some generic shock boots, ones that are flexible. That's what I use. They fit the top of the strut and you just use a big zip tie to hold them at the bottom of the strut.
Old Jun 5, 2006 | 08:52 PM
BioV's Avatar
I don't run them. But I live in sunny Southern California where we do not ice or snow and the roads do not have to be salted. nor do I ever encounter bad roads with heavy dirt here. I have been running Koni Yellows without the original dust boots on them for about 5 years and before that it had some Tokico Blues on it for about 8 years (they were fine when I pulled them off, I changed them for a better performance damper when I decided to build the suspension a little more hardcore.) This car has always been a daily driver.
Old Jun 8, 2006 | 12:10 AM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Does anyone offer a 4X4 dust boot to fit a koni?
The stock dust boots limit the amount of static camber I can put in with the spoon mono ball strut mounts.
I want to keep the pistons clean in case i go agricultural.
Old Jun 8, 2006 | 02:27 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
found these at pep boys.. ended up being around 30 bucks, which I thought was a bit much for what they are..
if I knew of these, I'd probably go this route.. Kirkey makes these for dirt track racing..
eBay Motors: Kirkey Black Coil Over Covers ODX dirt LM UMP IMCA (item 8073008063 end time Jun-13-06 14:54:52 PDT)
Old Jun 8, 2006 | 12:13 PM
Shagwell's Avatar
Car: projects.......
...coil-over car don't have them..... - I've run w/o for years now, no issues, but I'm another guy who is smart enough to stay away from that cold white crap and everything that goes with it....
Old Jun 8, 2006 | 08:18 PM
SDIF's Avatar
Thanks for the help!
J-money
Jan 4, 2019 09:45 AM
Fox118
Sep 12, 2015 09:29 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
89 formula TPI
Sep 8, 2015 08:00 PM
SG91camaro
Sep 5, 2015 10:27 PM
