Tire Selection..
Old Jun 13, 2006 | 09:46 PM
83Chevy_Camaro's Avatar
Car: 1988 Camaro
Engine: 1988 chevy pickup 350 TBI (rebuilt)
Transmission: 700r4- Bowtie overdrives
Axle/Gears: 2:73's
Tire Selection..
As of now i have 225-65-15's all around.. 65's are hard to take off when, The road is wet, sand on the pavement, and when im at the drags, Best 60ft is 2.5 seconds worst was 3.8seconds with a .79 reaction... I dont think 60's will make a big enough diffrence.. maybe 55 or 50's? what's the widest i can get without backspacing? I only want 2 wide tires for the rear.. i think everyone can understand that..
Thanks, Nick
Heres what i have now,
Premium Touring All-Season Radial.
An ultra premium touring radial that combines all-season performance, crisp handling and long mileage!
Last edited by 83Chevy_Camaro; Jun 13, 2006 at 09:48 PM. Reason: Automerged Doublepost
Old Jun 14, 2006 | 08:33 PM
Car: 1988 Camaro
Axle/Gears: 2:73's
and would like to keep the rims i have now, which are stock 15X7..
Old Jun 15, 2006 | 01:18 AM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
You're getting wheel spin cause 225's are tiny. The largest you can go would be 245/55/15, and there is not a lot of tire selection in that size.
Old Jun 15, 2006 | 08:51 PM
Car: 1988 Camaro
Axle/Gears: 2:73's
What would be better for drag racing and street?
Old Jun 15, 2006 | 10:12 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Wider would be better.
You could get some 16" Z28/Iroc wheels and put on 255/50 tires for even more performance
Old Jun 18, 2006 | 09:48 PM
Car: 1988 Camaro
Axle/Gears: 2:73's
50's will fit? I wont have clearance problems?
Old Jun 18, 2006 | 10:12 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
255/50 on 16" IROC/Z28 rims will fit fine. Just make sure you get the right one. The front and rear offsets are different
Old Jun 19, 2006 | 03:36 AM
CrazyHawaiian's Avatar
Car: too many ...
If you do a search you'll find that people have run 275's on the stock 15x7's, you could even do a Drag Radial. It wouldnt be within the recommended widths, but because there is so much sidewall the 275's baloon and stretch, and according to some people on these forums, works great. If I did it with 15x7's for drag racing application I would go wider than 235's but not as wide as 275, maybe 255 or something in the rear and then 225's in the front.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
