sway bar clam sheels all the same?
Just wondering if i need new sway bar clam shells for the bigger stock bars I just got or are they all the same and it is just the bushing that is different? (eg. going from 32 to 36 on the front).
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I hope I understand. The metal housings that the bushings fit in are all the same. You'll need new bushings--I suggest TDS's greaseable 36mms and new endlinks, again available from TDS.
JamesC
JamesC
JamesC
JamesC
So you actually need new endlinks, why? different length? The bar will sit in the same spot, correct?
JamesC
Car: Nothing stock- I screw with everyth
Engine: Hook&Ladder #8
Transmission: Morris Code
Axle/Gears: AxleROse CD Collection & Scuba Gear
Originally Posted by DRR
I would NOT recommend using the factory clamshells with polyurethane bushing put into them.
http://www.Top-DownSolutions.com/pro...products_id=42
JamesC
Those are wider band GM style clamps. Its the narrow GM type that I was refering to. GM offers two types on 80's cars and trucks. I was thinking these were the narrow ones from the factory originally but I must be mistaken. I do not have anything factory on my car leftover to remember.
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The greasable bushings from Spohn have a hole that lines up with the zerk on the shell, and then has small groves on the bar contact surface of the bushing for the grease to flow into.. Dunno about the other brands.. Spohn's also have real nice beefy shells..
When rebuilding the suspension on my cars I've only used new endlink bolts if I changed the ride height. Reason being they are only threaded so much, and combined with however long the endlink spacers are, it may or may not be enough thread to tighten them properly. When you lower the ride height the angle of the swaybar tabs change, so might have to modify the spacer and run a bolt w/ more threading to maintain that angle. But on a stock height car I always reuse the bolt and bushing stops (thats what I call em) unless they are damaged/rusted, I consider them a non wear item in a sense, just change the bushings themselves. If I need new ones I usually try the JY first, but last ditch scenario you can buy em from Autoparts stores (Autozone, Checkers, etc). When I've used aftermarket bolts with more threading in the past they were from PST.
JamesC
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
thanks for the info guys. So here is another siilly question. Are you supposed to tighten the end links down when the car is on the ground kind of like control arms or does it matter?
For OE endlink bushings, there is a torque spec. For poly, snug plus just a little (use Locktite). If the wheels are drooping, and you set to the torque spec or "snug plus" the endlink will most likely end up being too loose.
Norm
darwinprice
17
Oct 11, 2015 11:51 PM
