South Side Machine Subframe Connectors
Old Jun 25, 2006 | 10:28 AM
Turboba's Avatar
Car: '89 TTA
Guys,
These are NO LONGER AVAILABLE, so who makes good SQUARE Weld In subframe Connectors?? NOT the Cheesy Sphon's or Alston's either..
Guys that RACE thier TTA's have said that ONLY square Tubing is the BEST!!
Thanks!!
Old Jun 25, 2006 | 02:42 PM
DRR's Avatar
DRR
Car: Nothing stock- I screw with everyth
Engine: Hook&Ladder #8
Transmission: Morris Code
Axle/Gears: AxleROse CD Collection & Scuba Gear
Here we go again- An expert on cheese- yet, has to ask - yet, knows the expert racers that do recommend them- yet, those expert racers can't help him.
Search on round Vs. square topic. You may learn something on stuctural design when trying to use square tubing without a ladderbar type contruction.
Old Jun 25, 2006 | 02:55 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
so ask the TTA guys
Chances are that you're not making enough power to exceed the limits of the Cheesy round SFC's anyway so what's the big deal?
Old Jun 25, 2006 | 02:57 PM
LT1FUN's Avatar
Well, I cannot comment on whether or not round tubing is more rigid than "boxed" steel, but I would imagine that boxed steel would be the stronger of the two. By how much, I don't know, but I think it's safe to bet that whichever design is "stronger" - It wouldn't be noticible for 99.99999% of those using it.
If for no other reason, I prefer boxed steel SFC's over round because they can double as a jacking point on our cars. (I hate having to jack up my car from the differential housing and/or kmember)
To answer your question though, UMI seems to be gaining quite a bit of popularity on this forum and they truly do look like an excelently designed piece. I'll probably be picking up a set myself in the next few weeks. They'll run you $200US
Link: UMI Performance Inc.
Hotckis also makes SFC's in boxed steel for our cars though they're nowhere near as popular for some reason.
They're a bit more expensive though compared to the UMI version. These will run you roughly $230US
Link: Hawks Third Gen Parts-82-02 Camaro and Firebird Parts - Camaro/Firebird 82-92 Hotckis Subframe Connectors
Choice is yours, but these are your only two options if you insist on going with boxed steel.
Hope this helps.
Old Jun 25, 2006 | 09:24 PM
Turboba's Avatar
Car: '89 TTA
TT1FUN Perfect!!!!! Thank You!
And to DRR I'm running Mid to LOw 12's @112-114MPH
with a Stock near Bone Stock TTA Setup -
K&N, Chip, 20PSI, Race Gas & Drag Radials--THATS IT!!!!
Old Jun 26, 2006 | 01:48 AM
DRR's Avatar
DRR
And this comment is to mean what to me?
Old Jun 26, 2006 | 05:13 AM
80's Al's Avatar
Car: 89' RS TPI,04' HEMI Dodge Q-cab
Engine: 383ci
Transmission: TCI 700R4, 3400 stall
Axle/Gears: 12 bolt 3.73
I am personally running Alston's an like them a LOT.
I like the look of the tube-style better. They also hve GREAT clearance.
They connect directly from the rear to the front frame. Connecting from the outside part(rocker-area) and coming across to meet the frame just does not seem like it would be as strong to me...just my
hope you find what you like.....
Old Jun 26, 2006 | 08:05 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I hate to hear that they're no longer available. I have a set on my Formula and had them on my to do list whenever I get to purchase a T/A.
Old Jun 26, 2006 | 12:41 PM
Shagwell's Avatar
Car: projects.......
Yesterday 03:57 PM
there's guys running 10's and 9's on the alstons and the spohns. I've seen the BMR's on a low 8 sec drag radial car.
- So basically what you're saying is that you're more worried about adding extra weight for no reason?
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
fbirdroller
Sep 2, 2015 10:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
