a-arms???
Old Jun 26, 2006 | 08:51 PM
superNOScamaro's Avatar
Car: 91 CAMARO RS VERT
Transmission: t-5
Axle/Gears: 10 bolt/3.08
a-arms???
i just did a search and couldn't find an answer. here is my question, if you can't use aftermarket drop springs on tubular a-arms with spring boxes do you have to go with a coil over kit or is there a company that makes a-arms with spring boxes set up for aftermarket springs? i don't want to have to go with coil overs i still want to use my springs that i have. i want to use the tubular k-member with tubular a-arms. any help will be greatly appreciated. thanks!
Old Jun 26, 2006 | 09:03 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I think all of the tubular k member makers for our cars offer them with A-arms that will work with the stock mcpherson strut/spring setup. Give some of them a call and see what they recommend running. You may be able to keep the lowering springs you have now if not drastically different than than stockers.
Old Jun 27, 2006 | 09:43 PM
Transmission: t-5
i haven't seen k-member makers make a whole setup including the a-arms with the k-member. whos have you seen that sells that?
Old Jun 28, 2006 | 01:04 AM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
BMR Fabrication Inc. look there
Old Jun 28, 2006 | 08:56 AM
Transmission: t-5
it looks like those a-arms will fit aftermarket springs. i guess i will have to call and make sure before i buy them. have you seen the k-member and the a-arms sold as a set though?
Old Jun 28, 2006 | 10:55 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Originally Posted by superNOScamaro
it looks like those a-arms will fit aftermarket springs. i guess i will have to call and make sure before i but them. have you seen the k-member and the a-arms sold as a set though?
They wont. Do a search for my post and I posted a letter from BMR stating that they will NOT fit. Just stock. They even said stock is kinda tight.
This weekend our at Carlisle I talked with UMI Performance and they said that a full K member, A arm line will be released in the fall that WILL WORK with differant spring combos.
Old Jun 28, 2006 | 10:25 PM
Transmission: t-5
hell yeah that would be awesome. well guess i have to wait until then to get my tubular front end.
Old Jun 30, 2006 | 08:57 AM
Transmission: t-5
so as far as anybody knows right now there are no a-arms that will fit aftermarket springs?
Old Jul 2, 2006 | 10:20 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Ive got spohns tubular arms w/spring perches & using G.C. weight jacks.The springs ground control offers with their weight jacks are eibach.
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
92projectcamaro
Sep 24, 2015 08:09 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
