the air ride update...highway results
Car: 91 Camaro RS
Engine: TBI
well had it out last week and then this week on pretty good highway runs to shows, today we went out a ways to a show along with my buddies chevelle...also bagged.....
The Goodies
On a full air ride tech setup, 17x9.5 Zr1's and 275/40's on all 4 eagle f1's, energy suspension bushings...everything else susp wise bone stock
The Results
The more i drive it the more i fall in love car rode amazing, at 95 mph it did not feel at all like a camaro but rather a nice new caddy, its stiff, nice crisp responsive handling yet a very gentle, VERY COMFORTABLE ride, the 275's up front feel a bit wide for colorado roads as it wants to pull all over whereever the ruts in the road are, i'm thinking of a 245/40 for the front and probaly keep the 275 in the rear but want something a bit taller to fill the well a lil more, the 275/40/17 is an entire new world compared to the 225/60/16's the previous owner had on it, handling is crisper and it rides alot nicer, no rub whatsoever front or rear at ride height....
The conclusion
If you have considered bags or are tired of messing with spring shock combos this is the way to go, it is unreal how well this setup works and just how well it performs....i truely am floored
The Goodies
The Results
The conclusion
Car: 88' Iroc-Z
Engine: LQ9
that's awesome! I've been looking into this since kandied got his so now theres something else to save up for. lol wonder if i can squat with 315's out back? hahaha
Car: 1988 GTA
Engine: 5.7L stock
Right on. Sounds like a nice compromise for us with daily drivers that still want a little fun. Roads in my area have super bad rutts too. Those 255/50/16's really let you know. Some highway runs I can get a super tight grip on the steering wheel and then have a locked grip afterwards.
Feel free to give us more updates. Did shocks come with that system?
Feel free to give us more updates. Did shocks come with that system? Member
Car: 1991 Chevrolet Camaro
Engine: GM 5.7L H.O. 350HP
Transmission: Rebuilt 700r4/Shift Kit/Servo
irocbirdbuilder, do you ever get any bounce going down the highway. What I mean is on my air ride system the potholes and larger bumps on the highway DO feel softer and more comfortable but sometimes the places where there is repeated little bumps make the car bounce more than it should. I am still working on what psi to run, though.
What do you usually run yours at?
No...although they don't tell you that before you purchase it!
Last edited by Maverick_IX; Jul 5, 2006 at 09:42 AM. Reason: Automerged Doublepost
You are not the first to make these arguements and nothing you said is wrong, just not always applicable.
For one an air ride setup replaces the coil springs, which is entirely different than air shocks and/or an air ride setup for leaf springs (such as your truck). These are VERY different in concept from load helper springs, and allow the car's suspension to work as it did before, the airbags do not limit or impede the travel and dampening of the struts, shocks or control arms.
You are right about the height affecting the alignment. Which is why one, specific, desired ride height is selected for driving, the car is aligned there and that is where it is driven.
As far as performance, they perform as well as any lowering spring that has a large amount of progressive rate and high rebound. Because when you think about it as the bag is compressed, the air pressure increases, increasing the spring rate. No they aren't going to outperform a super-stiff constant rate spring on the track.
Also, with the bobble effect during hard cornering, the TV show you saw probably didn't use a 4-way valve, which means air could transfer from side to side creating nasty diving and poor cornering.
I don't think you are incorrect, I just think you are missing the point. An Air ride setup means a smooth comfortable ride, even when the car is lowered. I have run 4 differnet sets of springs, and while about half could "out-perform" the air ride NONE where very smooth at all. An air ride setup also has the ability to get over speed bumps, into steep driveways, and slam the car when parked and I think you would be surprised how well they can handle with some new bushings and adjustable struts/shocks.
Car: 91 Camaro RS
Engine: TBI
Originally Posted by DRR
Please post what condition your front tires will look like in a few months. Pictures now and pictures later would be a great reference.
You simply can not be changing the car's front ride height on the fly without serious affects to the alignment and tirewear. Airbags are for "load control" and "maintaining a specific ride height when the chassis weight is changed dramatically from payloads".
I use them daily for over 15 years on my worktruck. They do not belong a performance car- If you think they do for what ever reason, then simply answer this question for me- Why don't racecars run airbags? LVery low mileage show car- then fine.They are all for show and looks. One of the TV shows had a review on how well they performed on a latemodel TransAm on both a road course and a slolam- it was a joke watching them try an shoot an angle of the car that best made it look good- it pushed like a pig tthrough the cones and was laughable. They cut the shot off before you could finish veiwing the car getting in over its head in the slalom- it was heading out of shape and fishtailing when he stabbed the brakes to try and drop the nose to get it to turn when he was about 4 cones into the slalom(couldn't make air ride look bad on TV, they were flipping the bill that day)
I have had 3 different systems on this truck of mine over the years(again for load control- I carry heavy loads. If I have the least bit of air in the bags and try to corner fast, the truck body rolls very very easily lifting the inside and then also dribbles and shkips as it slides through a corner bobbling the rear end out. I have to completely let all the air out entirely to get the truck to handle decently- I have actually fited a petcock valve in line to keep the lines open and empty so air can suck in and out freely allowing the normal suspension to work properly when trying to drive normal or aggressive- I only close the valve and capture air in the bags when I need extra payload help. Even with them slightly filled (about 8 psi) and I have about 200lbs of cement bags in the bed (200lbs is nothing overall when this truck can carry 4000lbs with bags filled to 80 psi) the truck still has that bobble and roll feeling when going around a corner. So even weight compensating for the extra "spring" load of the bags does not help handling characteristics of bags- they do not handle well at all- they promote inside lift and balloon boble effect when compressed on a bump- the back of the truck will compress and then jump.- Same feel as sitting on one of those old Hoppity-hop toys(any old timers remeber them?)
First off...you get your desired ride height, mine is just about the stock ride height as i measured out before i tore anything apart....stock ride height is about 65psi in the rear and 105psi up front, i usually run my side a few pounds higher to compensate for my 200 pound build....
Now any adjusting is done when i go down the road is minimal a psi or two here or there, when you setup airride on these cars you have it aligned at YOUR RIDE HEIGHT
ie, i slam it at show, crank it up to get over dips and bumps safely at low speeds, run it back to 105 up front and 65 out back and bam your alignment also returns with the old wheels and tires i put almost 5k on the airride and alot of that being shows with some travel involved and the tires are wearing dead even
I have buddies who have been running the same tires on bagged trucks and cars for the past 3+ years and have worn even....if it is installed correctly you wont tear up tires
I am running these on a completly otherwise bone stock suspension only changes being the sway bar bushings up front, i still havent upgraded shocks yet and the handling is amazing, it is extremely tight and i get no old tore up suspension box chevy, car feels like its in teh ocean feeling to put it simple, the car rides stiffer than the stock coils did, yet it is comfortable.....
Look into your pro street cars, alot of them are running air setups due to the adjustability, i've been ot the track quite a bit and there are 57's and alot of mid 90's impalas getting into low 10
s if not more on air setups....
Whatever your opinion being until you experiance the kit YOURSELF on YOUR performance vehicle there is no rreason to bash the setup, because of how the load bags on your truck feel, if air is not your cup of tea then fine but i have alot of friends running this stuff on performance cars and none of them will go back to the old combos they ran, my side to side handling is incredible, 2 way valve setups you get a ton of lean side to side however with teh 4way, unless you know the car is air ride equipped you have no way of telling
Best money i have ever spent on the car
I don't think Dean is really trying to talk bad about the airbag setup, just giving his opinion that they might not be the best choice for someone that wants all out handling. My advice would be to not take it personally. Most of the posts in here about Airbags are similar to this one. The owner of the new setup is really happy with how it rides, so they let people know. Rides great, performs great, etc, etc. Then people that are into racing step in and give their opinion based on what they have experience with. The one thing we're always forgetting is to consider what people are comparing against. Comparing a new Airbag setup to a blown out worn 100+k mile suspension setup would undoubtably give different results than comparing it a setup with all new parts, or a modified setup like the stuff Dean has. So take it for what its worth.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Yeah, Dean is actualy a really nice guy. I haven't had the chance to meet him in person, but I bounce ideas off him via e-mail all the time (lol, I am never sure what his username here is).
Anyway, to add to this discussion. Karl Hunter (of Hunter Motorsports), and I were having a discussion about this not to long ago. Here are Karl's thoughts on the matter.
Anyway - about air suspension in performance vehicles...
For a venicle in a performance application air suspension is not the best
choice, and there are many reasons, most of which pertain to "spring rate"
With metal springs it is very easy to control spring rate, and that rate is
very consistent throughout the range of travel within the springs physical
limitations. For example - if you have a metal spring that has a 1000 Lb/In
rate then it will require 3000 Lbs to compress the spring 3 inches, and
another 1000 Lbs to compress it an additional inch and so on.
With air springs, however, the rate is determined by the volume of air
inside the chamber and the dimensions of the chamber - and that rate is
constantly VARIABLE - and according to the ride height with an air bag type
spring, the rate will be different and continuously variable for different
ride height settings. The more volume in the chamber (heigher ride height)
the softer the spring will be. The less volume, the stiffer. The biggest
problem is the non-linear way that an air bag spring responds to changing
loads - it may take 1000 Lbs to compress the spring 1 inch - but the next
inch may be 2000 Lbs depending on the dimensions of the chamber. Also - in a
roll condition the outside loaded wheel will have a rising rate spring
working on the suspension where the inside wheel has a decreasing rate
spring. You follow? Everything is constantly changing with an air
suspension. Setting corner weights becomes almost impossible - and if you
can adjust each corner individually, by the time you get the corner weights
set on the car you could end up with completely different spring rates at
any given corner with no way to resolve the issue, even though the "air
pressure" may be the same. Pressure and volume are both critical, but you
get stuck with the air bags that are supplied and those are what determine
what characteristics the spring will have - and in most cases the air bags
are generic and there is nothing you can change. Ideally, you could set the
air spring to have the correct volume of air (nitrogen would be better) and
then shim the spring (or use a threaded adjuster) to get the correct height
- but this is never the case.
Metal springs are used in racing cars for all these reasons. Consistent rate
- easy to change rate - easy to change geight - linear - etc...
Not to mention that air springs are affected by temperature and
environmental conditions... that and the need for a pump and pressure
monitor - blah blah blah.
Karl Hunter
Hunter Motorsports
Vancouver B.C. Canada
Karl Hunter
Hunter Motorsports
I think everyone here insists on arguing because they feel any statements that do not directly support their own are trying to argue. I don't disagree with much that has been said either way.
My point is, if someone says an air bag setup is good for cornering or racing, then tell them where they can put there theory, in my opinion, they are wrong.
But I don't recall anyone here making that claim.
Also, air bags do create a variable spring rate, although it is higher the more air that is put in the bags, not lower. This does and will create the bobble effect over larger bumps. But I think people who are running the AirRide setup prefer the bobble over a stiff suspension or one that hits the bump stops. (Most of us probably got sick of female passengers complaining about the ride)
I went from a setup with new shocks/struts, long springs with a rate lower than V6 springs, and new rubber bushings; and the AirRide still rides better on rough roads.
So, as much as people try to make it one, there isn't really an argument here. If you want and fine tuned autocross suspension go with coil-overs or metal springs, poly bushings, adjustable shocks/struts. If you want a car that rides like a town-car, even when 1.5" lower than stock than air bags can be the answer. (and as much as I hate to admit it, a parked camaro does actually look good with all the air let out.)
---P.S. CoolRide has double convoluted up front, barrels in the back, Shockwave can be run with or without CoolRide setup.---
lol... i knew i stayed away from this site for some reason.
yes my struts were up for sale as i have two pairs now when i was considering putting them on my 91 vert but it was cheaper to do the standard bags up front.
$1300 for anyone that is looking. brand new qa1 12 ways with the strut bags from air ride. you'll need a coilover conversion front end though. rides very well, a little better then the standard bag setup up front but not much. more for the one who needs room for turbo setup or long tube header clearance.
glad to hear your air ride setup is working good..
Mating them to something like the QA1 adjustable shocks makes people that really don’t know what handing means and judge it by “stiffer ride, it moves around less… must be handling better” makes them feel better even though real world you’re just ending up severely undersprung and overdampened…
Now with coil spring suspensions, most around here that are putting lowered coils on the car are hitting the bumpstops abruptly and/or are too softly dampered not controlling the spring recoil/ or simply as I have describe many times before they do not have a "good" shock with good chassis control valving.
Funny how I have one of the lightest sprung weight cars around here (having the small lightweight 60*V6) and yet I have some of the stiffest springs in my car (at a little over 800lbs) but I have one of the best riding cars around so much so that not only does my wife NOT complain about riding in it- she actually ons it and drives it daliy... and loves it. Its not only the marraige of componants you put in the car, but also how you install them and especially how you set them with freedom of suspension swing uninhibited, damper control to avoid slop and bobble yet not skip across the road, the proper articulation as not to bind, and finding the proper chassis balance so the car drives itself effortlessly.
Dean, I’d bet a big part of why our cars are so driveable even with what would be considered REALY stiff springs compared to a lot of others is that we still have tires with sidewalls on them (my formula usually has 245/50/16’s on it or my old 83 wheels/tires on it which were either a set of G60 hoosier road race tires (about 245/60/15 on all four) or some 235/60/15 F and 255/60/15 R BFG R1’s. Occasionally I’ll run an old set of 255/50/16 R1’s on all 4’s when I’m in the mood and don’t think the cops will harass me.)
The problem with doing a suspension correctly is- It take money and knowhow. Ya need both, and lots and lots of them. Here lays the problem with most of us. We are not all milionaires (I for one am on a budget constrainst as for probably most of you) however, when I do something, I save the money and do it correctly because I have the understanding just how important it is.
Most others are concerned with putting their money where it shows- like paint, rims, seat, steering wheel. I put it into such exotic but never seen items like drilled axles, carbon fiber driveshaft, cutom lightweight sspension parts( which for the most part I always order black- I could care less if they stand out. Most are not like me- they ant the looks. I personally know that no matter what color something is, I can see anything that is modified under a car. It doesn't need to be bright red with a sticker on it for me to think its been altered and someone layed cash out for it. Most people have no clue just how outragious my undercarage's are unless I personally point it out when explaining suspensions to people. I am not into looks first- I am into function first.
OTOH, if you really do want to make it low key, judicious use of a grinder, torch, muriatic acid and water can make even brand new or freshly modified parts look OEM.
Car: 88' Iroc-Z
Engine: LQ9
what all did you hav to buy to make it complete. I'm not familiar with it so i'm still looking into everything i need and airrides website sucks.
edit: nevermind i went back and did some searching and found the part numbers from when you first got it.
Car: 91 Camaro RS
Engine: TBI
I'm not putting up a fight against ddr or anything(sorry not online too much anymore) He makes some very good points as do others...i think its basically what its being used for, ddr sounds to be more cornering, handling kind of racing, my car has been built for 3 purposes
1.Street driven with decent manners
2. Straight line racing
3. Show
I'm not into autocrossing or road courses, the car was built to go fast in a straight line, win awards and get driven to and from the previous stated....
FOr me its great, i have the adjustibility i need to race it and drive it around town without tearing it up, and i can stop traffic when i slam it, its all personal preference, i love my setup, alot of people that have ridden in it are now looking into for they're rides
When all is said and done with the motor this winter i will be doing more suspension work, when the rear goes in its getting all new energy suspension pieces, aluminum ds, big brakes etc, tehn a good set of shocks, etc, but as i said i'm not in a rush to do it as the car works very well for what i have built it for
3. Show
Car: 91 CAMARO RS VERT
Transmission: t-5
Axle/Gears: 10 bolt/3.08
so would this be a good steet/strip set up for a third gen? and could you use tubular a-arms and a tubular k-member with the air ride set up?
Car: 91 Camaro RS
Engine: TBI
Originally Posted by 83 Crossfire TA
Well, that being said how about some pics?
Just search my name on apearance and detailing, theres tons of pics....or i try to get the best ones on my myspace....yea i got one www.myspace.com/baggedrs
SuperNOS, Imo this is an awesome setup for a street strip car, my experiance with it on the street is awesome, havent had it to the strip yet but playing around with it here and there seems to launch a little better letting a bit of pressure out of the rear.....only issue is the bags have to have pressure on them, for instance to jack the car up the bags have to be deflated as to not overextend them....so if you plan on launching hard enough to pull the tires off the ground then bags up front anyways wouldnt be my suggestion
dennisbernal91z
Wheels and Tires
Sep 6, 2015 11:12 AM
Linson
Aug 21, 2015 02:12 PM
