bigger sway bar...harsher ride
Just wondering, would a bigger sway bar up front make the ride a little harsher? My theory was that maybe each side on the front is now not as independent with a thicker bar....make any sense??
Just curious as I just went from 32 o 36 hollow and maybe it is just my imagination but it feels a little bit harsher.
Thoughts??
Thoughts??
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
A little harsher, you bet. The way the bar works (at least in a turn) is that when one front tire becomes unloaded in a turn it transfers the load to the other tire. Did you pre load the endlinks? Did you add poly? Did you change struts or springs? All will have an effect.
What do you mean by preload the endlinks? I did the final tightening after the car was on the ground. Oddly enough I can't tighten them anymore as I believe the nut has reached the end of the threaded part (it started slipping).
Car: 91Camaro RS
Engine: 305TBI
Transmission: 5-Speed
Axle/Gears: 3.08
I assume he meant just as you did, with the car on the ground or at least jacking up the control arm. Thats what everyone told me to do when I did this as well.
Yes,
A bigger bar will be alittle more harsh, but, the car will take turns much better, with less lean, leting you take corners at higher speeds.
So, it depends on what you want out of your car.
George
George
Car: 89 WS6
If you tightened the nut until you ran out of thread you have pre-loaded the swaybar. Ther are some posts about this if I get a chance I will do a search and post a link to one that explains this well.
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
(maybe)
There appears to be some confusion going on between overtightening the endlinks and preloading the bar. These things may occur at the same time, but it is not entirely necessary that for one to occur requires that the other be present as well.
Preload is when the bar is under load from one end to the other, as is the case when one endlink is too short, or the bar, chassis, or control arm is bent. Think in terms of one of the bar arms being pushed up, and the other down.
With poly endlink bushings in particular, you might notice this as a gap between the lower half of the bar bushing and the bar itself at one endlink only, before you tighten anything up. Tightening up to close such a gap loads the bar by that much, which changes your corner weights slightly (and introduces a tiny amount of rotation about the roll axis as well). With any split bushing endlink, the two bushing halves next to the sleeve on the “long” endlink and the two bushing halves away from the sleeve on the “short” endlink will be compressed to a greater extent than will the other four, and the bar’s behavior will be slightly asymmetrical (in right turns vs lefts).
Overtightening the endlinks “preloads” all of the bushings, perhaps even excessively so. But this does not necessarily mean that you've preloaded the bar itself.
It’s not a particularly good idea to do this, even though it will increase the effectiveness of the bar slightly. The bad news is that you’re now clamping the endlinks to the bar more rigidly, and when the bar moves in its arc it will force a greater amount of bending to occur in the endlink (whose other end has to follow the control arm arc that moves in a different plane). Rubber bushing halves will have short lives, and with poly or other firm bushing material the endlink will lose the argument instead, usually in fatigue rather than breaking off right away. That’s one of the reasons why most OE split bushing endlinks use relatively soft rubber pieces - they are intended to approximate a 3-D hinge (think Heim joint/ball joint/rod end for cheap, with no maintenance requirements or noise issues being additional requirements).
Norm
Norm
Thanks for the info NOrm! So I take it then that preloading is bad (based on your explanation that preload is actually twisting the bar a bit) Is that correct? If i understand that right and it is bent in one direction from the start, turning one direction would be stiff but then turning the other direction would be loose as the bar goes back to "0" and then starts bending the other way......do i understand that right?
So how do you know when you have the endlinks tightened enough? I just snugged them up until the bushings compressed a bit and formed to the pieces.......although as I mentioned it got to the end of the threads which i thought was odd. Maybe because they were used bushing so they were already squished a bit?
Car: '89 Firebird Formula
Engine: 305 TBI
yes your ride is going to be harsher.. you've increased your spring rate basically... just on one side at a time
how often are you hitting potholes that span the full length of your lane
Car: '08 Mustang GT
Engine: 4.6L
Norm
Thanks Norm.
One other quick question. I was reading a bit about that the bar shoud be able to rotate by hand in the clam shell bushings when the clamshells are tightened down and the endlins are not attached. Is this definitely the case and if so, how easily or difficult should it be to turn the bar? I think they were fairly tight when I put them on.
I noticed that the endlinks actually are on an angle inwards (with the wheels in the air anyways.....wouldn't the bar slide side to side if it were able to move in the clamshell bushings? I noticed on the front there is very little clearance between the bar and the K-member.
Car: '08 Mustang GT
Engine: 4.6L
Thanks Norm.
. . . how easily or difficult should it be to turn the bar? I think they were fairly tight when I put them on.
Side to side motion is indeed possible, but if everything is reasonably symmetrical the bar will tend to seek a central position. I have seen means of limiting lateral movement, though.
Too tight means there's extra friction in the system, which mostly adds more ride harshness than the small amount of damping that the friction also represents is worth.
Norm
Norm
Norm
Still wondering about a couple things though:
1. WHat size is the spacer between the bushings (end links) supposed to be on these cars? I don't believe mine are stock anymore so I want to know I am getting the right ones (at the store on the weekend the guy showed me 2trw ones and they both had different spacers yet are suposedly for this car).
2. Any idea if 92 camaros came with harder durometer bushings for the clamshells. THe bar is from a 92 and they certainly seem harder than my 21 year old rubber ones. THe end links this guy had were definitely harder as they were the GM blue ones.
Car: '08 Mustang GT
Engine: 4.6L
1. Long enough to make the bar arms horizontal as seen in side view. Your ride height figures into this as well, so on a car that’s closing in on being 15 years old it’s probably worth the time it takes to actually measure it. For what was shown to you, one may have been for a front bar and the other for a rear bar.
2. No idea.
FWIW, there isn’t much left in 15” max performance rubber that’s big enough for F-bodies and G-bodies. I’m just hoping that the upper shelf stuff doesn’t abandon the 17” sizes any time soon.
Norm
2. No idea.
Norm
sjorgens
Oct 1, 2015 07:54 PM
