tie rod and front suspension rebuild
Old Jul 12, 2006 | 10:22 PM
emayetete's Avatar
Car: 1988 iroc
Engine: '91 350
Transmission: 700r4 w/ b&m shift kit
i ordered parts from kragen and got the inner and outer tie rod arms and a centerlink. i began to unbolt the carter pin and take off some of the nuts from the outer tie rod arm and inner tie rod from one side. now i am having trouble getting the tie rod to drop out. the book says to use a ball joint puller but does anyone know of another way to separate the front suspension?
Old Jul 12, 2006 | 10:34 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
did you hit the top of the tie rod end with a hammer?
that's pretty much the only way to do it without a pickle fork, they are pretty cheap, like 20 bucks, some places even rent them out
Old Jul 13, 2006 | 01:47 AM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
easiest way i do it is, Take a hammer and hit the steering knuckle the vibration should let it pop right out
Other wise a picklefork will work
Old Jul 13, 2006 | 05:11 AM
emayetete's Avatar
Car: 1988 iroc
Engine: '91 350
yea i tried the pickle fork and a rubber mallot on the top of the tie rod. its not coming out. anyone have any suggestions?
Old Jul 13, 2006 | 06:43 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Make sure you've got the right size pickle fork.. so it fits between the tie rod and centerlink or spindle. If the opening between the tines is too small it'll get hung up on the tie rod bolt shaft instead of forcing the two pieces apart. Remove cotter pin (if installed), bolt, place fork between tie rod and centerlink then whack real hard. Rubber mallet may not impart enough whack strength.
Old Jul 13, 2006 | 10:40 AM
Car: 88 camaro
Engine: 355
I think the right size pickle fork is actually for a ball joint, if you used the one for tie rods it's too small. that's the way it worked out with my kit anyway.
Old Jul 14, 2006 | 01:37 PM
89rocket's Avatar
Car: 1989 RS
Engine: 2putt8
take some heat to the knuckles
Old Jul 14, 2006 | 02:08 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
Did you try hitting the steering knuckle ( where the tie rod attaches 2) on the side? the vibration should pop it out
customblackbird
Aug 15, 2021 10:16 PM
Ghettobird52
Apr 21, 2020 08:44 PM
Dialed_In
Aug 20, 2015 01:45 PM
