Is my torque arm bent?
Old Aug 10, 2006 | 07:16 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
I was in the process of repainting my torque arm and noticed some places in the arm that looked as if the arm is bent. I'm not sure if this is normal or not. Anyone have an opinion from the photos. I'd like to get a bmr or other aftermarket but monies a little tight right now. Thanks.
Old Aug 10, 2006 | 08:16 PM
92comaro/conver's Avatar
Car: 92 comaro-rs
Engine: 3.1liter/supercharged350 comingsoon
Transmission: 700R4 trans.
mine on my comaro is straight nothing like that,looks like rear yoke broke&drive shaft hit your torque arm
Old Aug 11, 2006 | 05:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yep, looks whacked.
JamesC
Old Aug 11, 2006 | 11:58 AM
pondriver's Avatar
Engine: 350 HSR
So, if it is whacked. Which aftermarket torque arm works well for light track action. Mostly on the street. Motor will have ~425 flywheel hp. Also, needs to work with hooker lt's and spohn subframe connectors. I've searched and it seems everyone has a different opinion.
Old Aug 11, 2006 | 12:08 PM
JamesC's Avatar
Imagne that! I'm using the non-adjustable Edelbrock, Hooker 2055's, and Global West SFC's. Zero problems.
JamesC
Old Aug 11, 2006 | 03:06 PM
pondriver's Avatar
Engine: 350 HSR
JamesC
Edelbrock torque arm:
This note is on the summit website "Notes: Only fits models with GM corporate 10-bolt differential and torque arm lips facing away from the driveshaft. " I'm assuming this will also work with a 9-bolt?
Old Aug 11, 2006 | 03:18 PM
JamesC's Avatar
Edelbrock torque arm: I'm assuming this will also work with a 9-bolt?
Nope, not without modification. Check the following link:
https://www.thirdgen.org/forums/susp...ock+torque+arm
JamesC
Old Aug 11, 2006 | 04:29 PM
pondriver's Avatar
Engine: 350 HSR
Thanks for the information. So, are we saying the stock torque arms are different between the 10 bolts and 9 bolts? If so, I'm guessing my options are pretty limited for an aftermarket arm.
Old Aug 12, 2006 | 12:26 AM
pondriver's Avatar
Engine: 350 HSR
OK, so I compared a 10 bolt rear and a 9 bolt and I see the difference in the housings that could cause an interference. Anyone know of a aftermarket torque arm that will fit a 9 bolt without mods?
92rsvortec350
19
Oct 9, 2015 09:39 AM
Nervous2
Oct 8, 2015 10:53 PM
luvofjah
Sep 26, 2015 08:28 PM
89newfun
Sep 16, 2015 09:28 AM
Ragtop Man
Sep 12, 2015 12:23 AM
