ahhh...finally installed konis and 12" brakes
Old Sep 2, 2006 | 02:40 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Whew!! What a week. But I got the new ls1 12" brakes on the front along with koni reds all the way around. The koni's and the eibach prokit is a good match. MUCH more civil and less off an ***-pounder / kidney puncher than it was with the same springs and kyb shock/strut.
To give you an example, I compared the rear shocks. While standing I could lean on the KYB's and theyd depress fairly easily (un-attached, that is). With the Koni's I had to lean my weight on them and push pretty hard just to get them to start to depress. WOW! What a difference.
The brakes are much sharper now and responsive, just like the handling. Man Ive been waiting for big brakes and koni's since i got my car about 4 yrs ago.
I am always amazed at just how great these cars can be with aftermarket replacement pieces and general maintence of wear and tear parts.
And I still have a poly transmission mount to install along with a BMR tubular torque arm!!!
Old Sep 4, 2006 | 12:02 AM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Amen brother. I went with the Yellow koni's and it is amazing how you can have much much more damping and the ride is so much better. It was hard to suck it up and spend it but the $680 for the Koni Yellows was probably the best money that I have spent on the car. The car is so much better at the track as well. All around it is great.
Old Sep 4, 2006 | 01:15 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
So here's the question, what do you guys both think of the koni's as a daily driver shock for bumps and ruts?
Old Sep 4, 2006 | 02:44 AM
Engine: Your Momma
I'm asking their opinion of what they'd be like to use on a daily driver.
Old Sep 6, 2006 | 04:22 PM
sorry, been busy latey and couldnt get back to your question. Um, I talked to steve spohn when I bought them. I was going to go with the yellow's but he said that they'd probably be too harsh for the street. He also said that the eibach springs and the koni reds were well matched and would be good for the street.
I live in a town with crappy streets. The streets are still crappy, but the koni red's have soften'd the blow. The car is way tighter now and feels much better. I love them.
Old Sep 6, 2006 | 08:51 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
I have Koni yellows and sport lines, they absolutly rock! the konis are awesome compaired to the KYB gr2s
Old Sep 7, 2006 | 07:49 AM
AZZ28's Avatar
Car: 1990 IROC
Engine: l98
I am comfortable using the Koni yellows as a daily driver. I could be wrong, but I believe the Reds and Yellows have some over-lap in their dampening characteristics. The most aggressive setting on the Reds is slightly more aggressive than the lowest setting on the Yellows. I recomend the Yellows.
Old Sep 7, 2006 | 07:02 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I have the yellows on mine. Rear only, but they are much better than the ones that were on it. They are a bit much for the Pro-kit, IMO. I want some stiffer springs for mine once I get the front Yellows.
Mine is a DD, by the way.
Old Sep 7, 2006 | 10:37 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
You could do either. So far I like the Yellow's on the softest setting for the street. It is so much better than it was before with the cheap struts and original bilsteen rears. If you go to track days you might want the yellows. If you don't, get the reds. So far I feel like the yellows can go way stiffer than I need, but I might want it when they start to wear. Not sure.
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
red90IROCls1
Aug 25, 2015 06:56 AM
