Shock recommendation - driver duty, not racing
Old Sep 11, 2006 | 11:59 PM
G8T8A's Avatar
Car: '88 GTA
Engine: 5.7L
Transmission: 700R-4
I need to replace the shocks on my GTA. I am only looking for an "OEM replacement" ride. I am not looking to make it any stiffer or harsher. A stock third gen WS6 is stout enough for me!
I can get a good deal on Delco shocks at my dealer, but if any of the major OEM replacement brand/models are regarded highly around here, I'd get a set of them. Thanks for any suggestions.
Old Sep 12, 2006 | 12:04 AM
quick ones's Avatar
Car: 85 firebird
Engine: 355 soon to be 406
Transmission: th350
Axle/Gears: Summers Bros 12 bolt 4.56
If $ is not a problem Bilsteins are the way to go.
Old Sep 12, 2006 | 12:13 AM
G8T8A's Avatar
Car: '88 GTA
Engine: 5.7L
Do they have various grades to choose from? They aren't harsher? I put Bilstein HDs on my 2001 T/A along with an Eibach Pro-Kit. I hate the ride. I assume and hope most of the harshness is from the lowering springs.
Old Sep 12, 2006 | 07:45 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
monroe sensa-trac would be what you are looking for. $150 for the set at Advance or Autozone.
Old Sep 12, 2006 | 12:28 PM
G8T8A's Avatar
Car: '88 GTA
Engine: 5.7L
Thanks! That's the advice I was looking for.
Old Sep 12, 2006 | 11:15 PM
quick ones's Avatar
Car: 85 firebird
Transmission: th350
Maybe I should of been more specific because Ive never used bilsteins on an F body but I have on a Grand National and trucks before they were awesome the ride was way better after putiing them on.The truck shocks where HD but I think the ones on the GN where the sport version
Old Sep 13, 2006 | 12:17 AM
Zepher's Avatar
Bilstiens for our cars are expensive (sports and HD), upto $700 for a set depenging on where you buy..
I went with KYB GR2 for the fronts and KYB Gas-A-Just for the rears. $175 at Advance for set I am running and $150 for all 4 GR2's.
Old Sep 13, 2006 | 07:01 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
Zephper, is that gr-2 and gas-a-just setup used with your sportlines?
Old Sep 13, 2006 | 01:00 PM
G8T8A's Avatar
Car: '88 GTA
Engine: 5.7L
How do they perform compared to stock or to the Monroes you named?
Old Sep 13, 2006 | 04:54 PM
Zepher's Avatar
sully91rs: Yes I am using those shocks with my sportlines.
G8T8A: the KYB's might be a tad stiffer, but not much. I got my new set of KYB's for free from a friend who went with the Bilstein HD's. KYB's have a lifetime warranty so I just took them to Advance and got them swapped for new ones. My friend is the manager so I didn't have to have a receipt.
Old Sep 14, 2006 | 12:02 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
How well does the gr2 and gaj setup work with the sportlines? I'm looking to change out my saggy stock springs for prokits, but I wasn't sure if gr2 and gas-a-justs would work with it. I have been thinking I'll need to get the KYB AGX.
Old Sep 14, 2006 | 12:20 AM
Zepher's Avatar
I have no problems with my setup at all, and the car that the KYB's came off was running the Pro Kit and he had no issues either..
AGX would be a better choice, but 3 times the price.
Old Sep 14, 2006 | 10:49 PM
quick ones's Avatar
Car: 85 firebird
Transmission: th350
Ive had KYB's on so many different applications ( mostly gas a justs) liked them on everything I put them on>
Old Sep 17, 2006 | 04:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I agree, the KYB gas-a-just and GR2 combo is pretty popular for a reason - virtually stock replacement cost, (apparently a lifetime warantee too eh?), and they work a bit better than brand new Z28 stuff.
I have them on my car with moog 5664's and cc635s, and I love the ride. Hard, but not unbearable.
Old Sep 17, 2006 | 04:54 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
GR(2)umpy
For idle readers, I had the KYB combo mentioned. That was many years ago. I found the fronts soft and the rears hard. I went to the yesteryear option of Monroe F1s. The fronts are still in place. One of the rears gave up 4 years ago. You should have heard the stiffled laughter I got when I tried to collect on the lifetime Monroe gaurantee. I put Bilsteins on the back. The combo seems to work. Mind you it has been years since I've been near roads to exercise the suspension (Florida is flat with lots of 90 degree intersections).
Old Sep 17, 2006 | 08:39 PM
red3rdgen's Avatar
Car: 2 1989 Formulas
I run the KYB GR2's on most of my cars and they are easy to find on ebay for around 100 for a full set.....
Old Sep 17, 2006 | 09:22 PM
SmallTires's Avatar
Car: 1984 Camaro Z28
Engine: Roller 350
Axle/Gears: built ten bolt 3.73's
I have the sensa-trac monroes and they work great for a daily driver. Not super spongy like an ultra cheap shock but not harsh like some shocks on the market. Not the best choice for autocross but great for daily driver duties. I am very happy with mine on all four corners.
Old Sep 18, 2006 | 12:40 PM
G8T8A's Avatar
Car: '88 GTA
Engine: 5.7L
After passing up a set of never driven KYB GR2s from a friend at a good price, I am getting the Sensatracs. If they're softer than stock WS6 struts/shocks, it won't be too bad.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
my86bird
Oct 23, 2015 12:20 PM
Amillionoh7
Sep 5, 2015 11:44 PM
SG91camaro
Sep 5, 2015 10:27 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
