NASTY wheel hop
Old Oct 22, 2006 | 09:41 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
NASTY wheel hop
So earlier I attempted to do the first burnout in the ******. (just got it)
The tires started melting literally as soon as I hit the gas, but about 5 seconds into it, it started wheel hopping like crazy.
I have seriously never felt/seen anything like it. Crawled under the car and saw nothing that popped out at me. All bushings/torque arm/lca's etc looked fine.
Any ideas, I might throw some slapper bars on it, but it shouldn't be wheel hopping like this to begin with.
Old Oct 22, 2006 | 10:33 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
On other burnouts it never did that?
Have a low or flat tire recently?
Edit: I just reread your post, You probably need lower control arm relocation brackets, If it's really bad it's possible that the old owner had a low of flat tire and used that flat repair in a can stuff.
It settles in one spot and causes a hellofa shake when u get the tires spinning
Old Oct 22, 2006 | 10:36 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
I just bought the car yesterday, its was the first time I ever tried to light em up.
It has no problem power wise, just don't understand the gnarly hop.
Old Oct 22, 2006 | 10:37 PM
Car: 88 camaro
Engine: 355
Bring it to the tire shop and have the wheels balanced
Old Oct 22, 2006 | 10:40 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
I honestly don't think its the wheels.
I do have a set of stock rims w/ brand new tires, I might throw those on and see if it helps at all.
Old Oct 22, 2006 | 10:49 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
It's your lower control arms. F-body's are bad about wheel hop with those weak factory LCA's. A set of Spohn boxed LCA's fixed the wheel hop in our firebird. It would shake the whole car when we tried to blaze the tires, put new bushings on the factory ones and still did it. Changed to some aftermarket LCA's and cured it completely.
Old Oct 22, 2006 | 10:52 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
Hmm..LCA's are pretty cheap, I'll have to pick up a set soon.
Old Oct 22, 2006 | 10:54 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
replace your rear shocks first, they're only $15 a side anyways for parts store cheapies...I would imagine that would be the problem over the LCA angle on a stock car.
Old Oct 22, 2006 | 11:04 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
The shocks are actually new, I also have new KYB struts for the front that I need to put in.
And its not stock.
Old Oct 22, 2006 | 11:19 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Torque arm.. no questions asked.. i had all the rear suspension parts but no torque arm and i shattered a differential from wheelhop.. after i got the torque arm, no wheelhop..
Old Oct 22, 2006 | 11:57 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
didnt change the angle of the LCA's, just put some some that more more rigid.
Spohn Performance, Inc. still running the stock torque arm.
Old Oct 23, 2006 | 04:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think you'd have a tough time putting slapper bars on this car...
The general things to do to fix wheel hop are
rear shocks/springs
LCA bushings & LCA's.
If the car is lowered, you may need the relocation brackets.
With the car parked on dead level ground, check the angle of the LCA's front to back, higher in the front, or higher in the rear?
Higher in the REAR can cause that.
Loudnproud86
Jul 14, 2016 12:59 AM
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
