Car leans slightly to the passanger side..theoretically....
Old Nov 16, 2006 | 09:25 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Theoretically, since my car is leaning to the passanger side rear about 1 inch, and seems to be the reason why my passanger side door is out of alignment, installing subframe connectors onto the car while it's on a lift should straighten it back out. I figure this becuase when i have had my car on the lift at work before, I happened to notice the passanger side door worked like new again when all 4 wheels were up off the ground. So, I am going to get some sfc and bolt/weld them in, and I will let everyone know if this straightens my cars dog tracking out/ mal aligned door out.
Last edited by PneumaticTire; Nov 16, 2006 at 09:26 PM. Reason: I suck pretty bad at typing.
Old Nov 17, 2006 | 05:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
do you have a dead shock or a busted spring?
Old Nov 17, 2006 | 08:00 PM
No, already looked. SHocks are pretty old, but not leaking, and the springs and insulators looked ok? I am really leaning towards it being chassis fatigue from the torque. It's also a weaker t top car. ANy other suggestions I should look at first? I am getting sfc regaurdless, since I have always wanted them anyway.
Old Nov 19, 2006 | 01:14 AM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
Shocks don't support the weight of the vehicle, only the springs. Springs don't have to be broken to cause a vehicle to lean. One could be more fatigued than the other. Just look at an S-10 or Blazer some time. Chances are the driver's side will be slightly lower than the passenger side. I'm not saying that SFCs are a bad idea, I'm just saying there's no guarantee it wil fix your problem. And if you suspect your car is bent/twisted it wouldn't be a bad idea to take it to a body shop and have your frame alignment checked first.
Azrael91966669
25
Jun 20, 2017 04:04 AM
apie2546
Aug 10, 2015 05:43 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
hokis
Aug 9, 2015 03:57 PM
