lowered car
Old Jan 7, 2007 | 01:51 AM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
lowered car
iknow it has been a while since i lowered my car, i need to know if the car needs shorter sway bar end links, it has been three years
Old Jan 7, 2007 | 02:21 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
yes you can put 1/2 shorter ones on there and it'll help it out somewhat.
Old Jan 7, 2007 | 11:46 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Where do you get 1/2" smaller ones? Also how would this affect/effect driving and road feel?
Old Jan 7, 2007 | 11:56 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
summit sells them Get the universal sized ones.
Old Jan 7, 2007 | 01:36 PM
xpndbl3's Avatar
Car: 1984 Z28
any parts store typically has the poly bushing ones from energy suspension, just measure the center metal piece and get one 1/2" shorter.
Old Jan 7, 2007 | 04:35 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
But how does this affect anything? Like lets say I keep the ones that come with my swaybars.....
Old Jan 7, 2007 | 07:40 PM
xpndbl3's Avatar
Car: 1984 Z28
if your car is lowered you should get shorter endlinks to keep sway bar angles in check. if it's not lowered don't worry about it.
Old Jan 8, 2007 | 08:37 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
I dont just want to hack it or anything. So how do I know what correct length to have? I can order endlinks but nobody sells shorter sizes?
Old Jan 8, 2007 | 08:55 AM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
what is the reason for getting shorter end links?
Old Jan 8, 2007 | 10:04 AM
xpndbl3's Avatar
Car: 1984 Z28
energy suspension sells poly endlink ones in probably 30 different lengths. Not sure why you didn't read that as it was posted earlier in the thread, you don't go into vatozone and say "hi i'd like endlinks for 84 camaro, but make them shorter". Their computer won't help, they usually sell them down one of the aisles or they can be ordered once you figure out the length from advance auto parts or similar places.
Old Jan 8, 2007 | 11:23 AM
Demon355's Avatar
Is this really important to do?
Old Jan 8, 2007 | 12:23 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
A proper suspension should have the end of the swaybar (where the hole is) parallel to the hole in the control arm. Or as close as you can get it(it may interfere with other things).
Depending on how low you lowered it depends on how it should be spaced, none of us here can tell you exactly what you need w/o the car infront of us. I had custom aluminum spacers made for mine because I couldnt find endlinks short enough.
Will it work w/o shortening them? Obviously yes, it has for you for 3 years. Will it work better properly spaced? Yes.
Old Jan 8, 2007 | 01:56 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Nobody makes different sized endlinks....just in case you do lower your car. So I am looking at custom work.
So is that why endlinks come in 19mm-24mm? <~~~For the rear
Hey I'm just learning too.
Old Jan 8, 2007 | 07:36 PM
Dale's Avatar
Engine: 350 S-TPI
ES makes different length endlinks. I have a chart out in the garage somewhere if you would like part numbers and lengths. IIRC there is about 10 on the chart. You dont HAVE to have custom work, I did because I wanted it this way. You can get new center bolts and carefully cut your stock spacers. Or go buy the closest kit.
The 19mm-24mm describes the DIAMETER of the swaybar, for the MOUNT bushings, not endlinks. Bar diameter has no effect on the endlinks.
chart was laying right ontop of stuff.
1.00" -- 9.8122
1.625" -- 9.8120
2.00" -- 9.8123
2.375" -- 9.8125
2.625" -- 9.8117 (commen replacement for stock setup on 82-92 fbodys)
2.875" -- 9.8118
3.375" -- 9.8119
3.4xx" -- 9.8124
4.25" -- 9.8149
4.50" -- 9.8121
Old Jan 8, 2007 | 07:55 PM
I went to AZ tonight and they carry a whole line of ES end links in different sizes..was right there up on the wall/shelf...along with other ES stuff
Old Jan 8, 2007 | 08:26 PM
xpndbl3's Avatar
Car: 1984 Z28
i think he's confusing sway bar bushings with endlinks and their different lengths they come in.
Old Jan 8, 2007 | 08:44 PM
Dale's Avatar
Engine: 350 S-TPI
Old Jan 14, 2007 | 01:51 AM
86irocterror's Avatar
i heard( not sure though)that the hole in the swaybar for the end link should be parallel with the side rail (the front sub frame) is this right?
Old Jan 14, 2007 | 12:52 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
1.00" -- 9.8122
1.625" -- 9.8120
2.00" -- 9.8123
2.375" -- 9.8125
2.875" -- 9.8118
3.375" -- 9.8119
3.4xx" -- 9.8124
4.25" -- 9.8149
4.50" -- 9.8121
So try one of those as reading up top someone stated you want endlinks 1/2" shorter....to start with anywho...plus I am only lowering my car 1" maybe only .75"....so I dont see going to short with my setup...but these are what i should start with?????
Old Jan 14, 2007 | 08:36 PM
Dale's Avatar
Engine: 350 S-TPI
You could try one of them 2. Are your springs already in and been driven on? If so, turn the wheels and look to see how hiked up your swaybar is, and measure to see what it would take to get that end parallel
should be parallel with the a-arm where the endlink goes thru.
Old Jan 15, 2007 | 11:08 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
I havent lowered it yet just trying to get everything ready....well some parts at least like what to do when lowering it.....so THANKS FOR YOUR HELP. I'll be sure to try this out when I do and let you guys know. I'll post my setup and which endlinks I used or work the best. Thanks again.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
