motor and tranny mount
Old Feb 1, 2007 | 07:13 PM
MikeH92RS's Avatar
Car: 92 Camaro RS
Engine: 350 .030 over compcam 12-212-2
Transmission: T350
Axle/Gears: Borg/Warner 9 bolt 3.70
To all the PRO's that have done engine and tranny swaps, what or which motor mount and tranny mount do yall recommend?
350 motor
350 turbo tranny using the SPOHN crossmember with torque arm.
Mike
Old Feb 1, 2007 | 08:02 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Most people use the Energy suspension motor and tranny mounts. Both work great though the motor mount raises the motor up in the engine bay and can cause certain intake manifolds to touch the hood.
Old Feb 1, 2007 | 08:43 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I used Prothane instead of Energey suspension. I don't know if this is true, but heard the the ES tranny mount was not the correct height. So just in case I ordered the Prothane brand
Old Feb 3, 2007 | 01:28 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'm not a pro, but I just used new stock rubber mounts. I didn't want excess vibrations. I'm keeping an eye on my tranny mount, if it fails as quickly as some people say they do, then i'll go poly on that.
Old Feb 3, 2007 | 02:10 AM
CrimsonDragon's Avatar
Car: 89 IROC - 85 Z28
Engine: 350 / 305
Transmission: 700R4 / T5
Axle/Gears: Stock
I broke 3 stock trans mounts before I went poly.
Old Feb 3, 2007 | 05:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I use ES motor and tranny mounts. It may be that the ES motor mounts are stock height but that "seem" to raise the motor because the OEM's have simply collapsed. With a drop base air cleaner, I experienced to problem with fit. The tranny mounts fit fine.
JamesC
Old Feb 4, 2007 | 12:57 PM
jcisthechamp05's Avatar
Car: 1987 IROC-Z
I also agree to go poly with the tranny mount atleast, cuz if your motor is going to be making some decent power your going to go through them like hot cakes.
Old Feb 4, 2007 | 01:55 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I used an ES poly trans mount and once it "breaks in" there is no additional vibration at all. I just use stock motor mounts and not had any problems with them.
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
