lowered people please...
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
well here is the car
now, everyone and their brother, tells me that i should lower the car. Ive been fighting it for a while now and am starting to give in. what is everyones opinion? i see sportlines around and that seems to be the spring of choice, any other options for a lowering of 1.75-2"? right now i have spohn's IROZ springs, which i think actually raised the car a bit. my biggest problem with the whole lowering thing is how do you jack up the car? im always working on it, changing things, and as it sits now i have to drive up on ramps made of 2 2x12" just to get my jack under the front without smashing into the air dam. how do you people who have these nicely dropped cars, jack up the front end? i do NOT like the idea that some people have of "jacking up the a-arm one one side, then doing the other." i think that is retarded. is there any other way?
thanks
thanks
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Just get a bigger set of ramps. I've got Sportlines on my Formula and have also used ramps since I bought the car new back in '91. Mine are from Advance made by Rhino I think, made from some plastic material. They get the car plenty high enough to put a jack under the front crossmember with no damage to the air dam. Nice ride BTW.
Car: 86 Trans Am
stupid question but, pic of ramps? i tried to make a slightly higher set of 2x12 ramps and the car pushes them before it get up on them. but i never thought i could buy a set of ramps that the car could actually drive up on that would fit under the car and not hit the airdam
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
nice car! but geez it looks like u have a lift kit on that thing...ive fought it too for a while but ive given in, i just got the sportlines since they make the car look amazing, and they will be goin in within the next 3 weeks. i would get the sportlines they will drop the car alot bc of ur new stiff springs and make that thing look even better. oh if u got the stock shocks u will want to put new ones in. im going wit KYB bc i have no money lol and i want better than stock performance but nothing to stiff bc its my daily driver.
i have some really old metal ramps that work great, i would look into a good pair, just google for some setups, u shouldnt have a problem with clearance issues. oh yea dont forget to get LCA relocation brackets and adjustable panhard rod. they are a must for ur lowered car
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
245/50/16s & intrax 2" springs. $180.00 from summit. (i didn't have the locker yet)
Last edited by 1989formula355; Mar 4, 2007 at 06:44 PM. Reason: too dumb to add the pic right
i drive the fronts up on a set of 2x4s and the lift clears no problem.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I drive up on 2 2x4's offset a bit, then the jack fits fine under the front end. Still have to "baby pump it" for a bit.
Car: 1991 Camaro Z28
Engine: L98 5.7L V8
Transmission: 700R4 Auto
I usually jack it from the sides. The driver side is simple, but the exhaust on the passenger is mind numbing. We have a "speed jack" so it's easier to get under there than the conventional floor jack.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
thanks! the wheels are powdercoated, i've since added a trans-am decklid, and a v6 hood with a summit cowl to clear the stealth ram. i need some new pics.
My car is low enough that I can't jack the front up. SO,I usually jack the rear of the car up first, Put the jack under the axle assembly first, - place jack stands under the axle tubes, move the jack to the front and go from there. It is a pain, but I don't have long enough ramps that will clear the front/lower radiator air deflector
-Andrew
-Andrew
Car: 86 Trans Am
hey, thanks guys, i think i'm ready to get a set of sportlines, one more question. how much will the handling be affected if i opt not to install LCA relocation brackets? i have a new motor coming and my little ten bolt will be obliterated shortly after, and i don't want to put the brackets on just to throw them away when the rear goes kaput.
Car: 92 z28
Engine: fast burn 385
Transmission: t56
new motor = enough power to kill the 10 bolt = enough power to twist the car = subframe connectors = best place to jack a car up ever!!
this is the only way i can jack my car up, and the front is lowered about 1.25 inches i think. i just jack up one sude and put a stand under the sway bar mount and go to the other side and do the same thing.
Car: 86 Trans Am
and im no newbie here, i have all the suspension work, PHB, LCA, STB, wonderbar, SFC, swaybars, the works, im not going to drop a 500horse motor into a stock chassis and pray to God is works and i dont die. the 12bolt will be comming after the swap is done.
anyway im going to just have to deal with ramps...
thanks guys!
Car: 92 z28
Transmission: t56
and why would you not just use the sunframes to jack the car up? i do it everytime i need to jack it up, and have done this for over a year. it works great and that was my point. im glad to hear your not dropping in a huge motor and praying to live, but my only point from above was about how the sunframes make a great point to put a jack on
86 TA I have the same springs you currently have and yes they do raise the car up a bit from stock, but they are stiff and make the cars handle better then the cars I've driven/riden in with sportlines, prolines, intrax etc. My choice was to cut 1/2 coil off the springs and was surprised it dropped about 1 1/4" leaving the car about 3/4" below stock ride height from the factory and looks really good. I am running long tube headers so lowering too much will not work, but a little lower than factory is perfect for me. Just an idea vs. spending $250 on a new set of springs when you actually in my opinion have the best aftermarket springs available for our cars in terms of handeling and ride.
Car: 86 Trans Am
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
To drive my car up onto ramps I made a set of ramp extentions out of a 2 x 12 about 36" long with rebar hooks on the end to fit into the holes on the ramp. To jack the front end I made ramps out of 2 x 12s stacked two high. Then my jack goes all the way to the 'K' member. Works for me.
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
