Lakewood Safety Loop Users, did you have to remove the console?
Old Mar 24, 2007 | 10:00 PM
92Z's Avatar
92Z
Like the topic says. Just wondering if you had to pull the console to install the F-Body Driveshaft Safety Loop? I downloaded their instructions, and it says to remove the seats, sill plates, and kick panels. No mention of the console. What was your experiences? Thanks.
Old Mar 24, 2007 | 11:00 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Lakewood Safety Loop Users, did you have to remove the console?
To do it properly you'll need to remove the seats and carpet or at least lift the carpet up to the driveshaft tunnel. The console could probably stay in place.
Cheap, poor way to do it is to drill holes from the underside right through the carpet and just bolt it in but then you'll see the bolts and washers on top of the carpet.
Old Mar 25, 2007 | 03:22 PM
brutalform's Avatar
You do not have to remove the console. Removing the front seats, sill plates, and lifting the carpet will get it done. BTW, what exhaust system are you using? The reason I ask, is if you are using the Mufflex "Y" pipe, you will need to modify the loop.
Old Mar 26, 2007 | 10:16 PM
92Z's Avatar
92Z
I running SLP 1 3/4 shorties into a single 3 inch. They claim they are 2 1/2 O.D., but they measure 2 1/4 O.D. My "y" is where the dual factory converters used to be. A dual 2 1/2 into a single 4 inch is on my list to do here shortly.
1992rs/ss
Jan 31, 2025 05:10 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
mx127
Aug 10, 2015 08:13 AM
3rdgenparts
Aug 8, 2015 07:09 PM
