GM part# help
Old Mar 30, 2007 | 09:41 AM
Danu81's Avatar
Car: Pontiac Trans Am GTA -89
Transmission: TH-700R4
GM part# help
Hi.
Can someone please help me. I need the GM part numbers for the tilt steering column lower bearing and bearing adapter for a -89 firebird
Thanks.
Old Mar 30, 2007 | 10:02 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: GM part# help
07805700 Lower Bearing
07832311 Bearing retainer
These should be what you need
http://www.gmpartsdirect.com/
Old Mar 30, 2007 | 10:17 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Re: GM part# help
Try;
Bearing (lwr) #7805700
Adapter #7805822
Old Mar 30, 2007 | 10:19 AM
Danu81's Avatar
Re: GM part# help
That´s what I tought also. So yesterday I got those parts but they don´t seem to fit at all, don´t even look like the old ones. So I´m wondering if someone who have a parts and illustration cd can give me some help.
Old Mar 30, 2007 | 10:45 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Re: GM part# help
If you've got an original steering column, pm me your vin# and I'll do an extensive search for the part #'s you need.
Old Mar 30, 2007 | 01:23 PM
Danu81's Avatar
Re: GM part# help
My vin# is 1G2FW2180KL225856
The parts i´ve got at home now are 7805700, 7832311 and 7805822.
These parts will clearly not fit.
The old part does not have a bearing at all, there´s only the plastic part and two rubber rings at each side.
Old Apr 8, 2007 | 08:00 PM
kauffmannl56's Avatar
Car: 89 firebird
Engine: 2.8 soon swapped 2 a 383 stroker
Re: GM part# help
I don't mean to sound dumb but are you talking about the bearing that is just below the turn signal mechanism and looks like a black rind with bearing in it? I have recently fixed the loose tilt problem many people have and noticed the bearing was in horrible shape. The bearings were falling out and now I am stuck with no car. Is the bearing that I am talking about that same one that you are asking about in this thread? Thanks
Old Apr 17, 2007 | 08:55 AM
Car: 89 firebird
Re: GM part# help
so anyone that can help ... ... ... anybody
Old Sep 23, 2010 | 11:05 PM
rjdavis2001's Avatar
Car: 91 Z28 Conv.
Transmission: 700r4 auto
Axle/Gears: 3.27 posi
Re: GM part# help
I seem to have the same problem with no bearing at the end of the coulumn also, did you ever get a part# or the correct bearing?
BumpaD82
Feb 26, 2016 02:57 PM
jtwoods4
Sep 3, 2015 10:19 AM
F0xBody50
Jan 7, 2002 02:43 PM
cort351w
Oct 26, 2001 07:35 PM
eddie89TA
Apr 28, 2001 01:28 AM
