twin turbo tire
Car: 1984 Camaro z28
Engine: 350 TPI Twin T70 turbos
Transmission: th400
Axle/Gears: stock putting in a 9" with 3.89
twin turbo tire
i am running a 350 twin turbo i want to know what the widest tire you can run on stock iroc rims the car is also lowered with eibach prokit
Car: '89 Iroc Camaro
Engine: 5.7 350 TPI
Transmission: 700R4 Automatic
Re: twin turbo tire
The widest tire for a stock is BF Goodrich's 295/50-16, but I don't think it will clear with you car being lowered.
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: twin turbo tire
HPE, thats pretty funny!
Mr. Twin Turbo, in all honesty, I would upgrade to the 4th gen wheels (17x9.5) and mount up P275/40R17s. Put the stickest tire on the rear, and a tire on the front that is good in the wet & dry. You will need adapters for these wheels. I have just this week make this swap.
Re: twin turbo tire
It alrgely depends on the intended usage of the car. - 1st off, the factory 8" wide wheels are't going to do anything for you, unless you put slicks on it(as reccomended by xpndbl3) - The widest tire you can fit on the wheel is a 255/50/16 which in a semi decent tire will out hook a BFG 295 T/A anyway. - If you have anything for power(I would hope) you need to look into swaping wheels. -
No matter how you go about it, I hope you have several suspension mods.
Transmission: th400
Re: twin turbo tire
thanks guy and yes i have complete suspention up grades
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
