Spohn A-Arm Guys
Old Apr 15, 2007 | 09:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Spohn A-Arm Guys
After doing research on this board, I'm on the fence about purchasing: Some members reported that the a-arms lowered their cars, another that breakage occurred. Should I be concerned with these accounts or should I bite the bullet and lay down my hard-earned cash? The car is only street driven, should that make any difference.
JamesC
Old Apr 15, 2007 | 10:32 AM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
Re: Spohn A-Arm Guys
Here is a pic of my car with the spohn a arms and the Eibach Pro-Kit springs (1" drop). The front of my car is basically slammed which might be partly because of the a arms. If you notice my rear sits way higher than the front, which I'm hoping will settle down after some driving. I couldn't even imagine what it would look like if I had the sport lines or something similar that provides more drop.
For some reason the pic didn't load. I'd be happy to email you a pic if you want.
Old Apr 16, 2007 | 08:25 PM
JamesC's Avatar
What did you use for bump stops?
JamesC
Old Apr 17, 2007 | 07:45 AM
Car: 1992 Camaro
Engine: 350 miniram
I used bump stops that slide over the strut shaft like on a coil over type setup. I thought about mounting the bump stop on the K member but this was so much easier and will work just as good.
Old Apr 18, 2007 | 06:33 AM
JamesC's Avatar
Brand, size?
JamesC
Old Apr 18, 2007 | 07:25 AM
Car: 1992 Camaro
Engine: 350 miniram
Global West makes the bump stops and they are 24mm in size. Works like a charm.
Old Apr 18, 2007 | 07:33 PM
Dr G's Avatar
Did any of you have trouble installing your Spohn A Arms? Were you installing the ones with perches for springs or coilovers? Did you use internal spring compressors etc?
Old Apr 22, 2007 | 07:02 PM
KhaotikRaje's Avatar
I wish I had seen this thread before I bought my a-arms, cause now I am getting a bit worried. I have Spohn's tubular k-member, fabricated upper strut mounts, tokico illuminas, sportlines and Spohn's tubular a-arms.
I haven't even assembled my front end stuff yet, but I will post up pictures as soon as I get the front end back together and the car off jackstands. I just hope the front end isn't slammed too much, otherwise I'll probably have to sell the sportlines and get different springs.
Old Apr 29, 2007 | 05:53 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I called Spohn a few weeks ago and ordered the a arms with spring perches. I specifically asked about the perches and they told me they have been redesigned not to lower the vehicle.
Anyways, I'll guess I'll find out when I install them in 2 weeks.
Old Apr 29, 2007 | 05:56 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
hey kris, let me know what you think of them, i may be wanting a set too.
Old Apr 29, 2007 | 05:59 PM
JamesC's Avatar
After all that I've read, I decided against them.
JamesC
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
Street Lethal
Aug 14, 2015 08:25 PM
SiCkRs
Aug 8, 2015 08:12 AM
