spring isolator question
Old Jun 19, 2007 | 06:16 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
i searched and couldn't find anything.
i'd rather have poly rear spring isolators for my 83 bird but i cant find any.
my question is: will the rear spring isolator from a 1967-88 Chevelle, El Camino, Monte Carlo fit on my Firebird? (p/n 311-7-1706-BL from prothane- $6.99 from jegs)
if not i need the height and width measurements off the F-body ones so i can see if they have a universal one in that size.
any help would be AWESOME since i've been trying to find something for weeks.....thanks.
p.s. if all else fails i'll just go to the local pontiac dealer and get the (4th gen) stock ones.
Old Jun 19, 2007 | 09:18 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: spring isolator question
FYI. According to Ed Miller, resident board brake guru, the fourthgen isolator will raise the rear end of the car.
JamesC
Old Jun 19, 2007 | 10:15 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
i also looked for them and had no luck so i just greased up and reused the stockers.
Old Jun 20, 2007 | 04:01 PM
yea i know the 4th gen ones are a bit taller but it doesn't matter to me.
does anyone know if the monte carlo isolators will fit???
and what are the measurements of the stock 3rd or 4th gen ones?
Old Jun 20, 2007 | 07:36 PM
JamesC's Avatar
yea i know the 4th gen ones are a bit taller but it doesn't matter to me. and what are the measurements of the stock 3rd or 4th gen ones?
If it doesn't matter to you that the fourthgen isolators are taller, why be concerned about measurements?
JamesC
Old Jun 20, 2007 | 11:57 PM
b/c i would like to get poly ones instead of the rubber and if th monte carlo ones wont fit i'd like to see if they have a "universal" one in the same size as the f-body ones.
Old Jun 21, 2007 | 05:42 AM
JamesC's Avatar
I see. Let us know what you find out.
JamesC
Old Jun 21, 2007 | 11:53 AM
formula_pilot's Avatar
Car: 89 Formula
Engine: LB9
Axle/Gears: 9 bolt / 3:45
JamesC
I bought two GM PART # 10290379 rear spring isolators from GM Parts direct. They are overall about an inch taller than the 3rd Gen isolators, but have an equally deeper pocket that the spring sits in, so there is no change in ride height. I measured the wheel well gap before and after installation and my car sat at the same height as with the original spring isolators.
Old Jun 21, 2007 | 05:22 PM
toms84ss's Avatar
No,G body isolators are different, they wont work.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
