Help - lowered car isn't lower up front
Old Jul 1, 2007 | 10:01 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
Put on a set of Eibach Sportlines on all four corners, a pair of bilstein hd shocks in the rear, w/a spohn adjustable panhard bar. The rears seems like they dropped in height, but the front is actually higher than the stockers. Any suggestions? The springs were on according to eibachs instructions - flat coil at the top so the words are right side up. New sway bar links, same struts/tie rods. It almost looks like the car is launching. Driving it settled it in some, but not nearly enough. The front is visibly taller than the rear.
Thanks!
Old Jul 1, 2007 | 10:40 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Re: Help - lowered car isn't lower up front
Did you index the front springs? By that I mean did you rotate them so the ends on the bottom were between the two wholes in A-arm. This will definetly cause the front to sit high.
Old Jul 2, 2007 | 04:54 AM
CrazyHawaiian's Avatar
Car: too many ...
Another possibility (though rare) could be the spring improperly seated up in the k-member pocket causing a coil to get caught on that ridge and bind.
Old Jul 2, 2007 | 05:23 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
just to add some to this post, I helped him install the new suspension components. The ends of the springs were indexed properly between the two holes in the a-arm. I've done several spring installs including a pro-kit on my Trans Am. I can't verify that the spring didn't seat improperly in the k-member, but it's hard to imagine it happening because of the way the seat is shaped it really leads the spring into place.
We taped the rubber isolators to the top of the spring while installing the same way I did on my car. I couldn't seat them perfectly in the k-member when installing without putting tons of compression on the spring first (which can be very unnerving!) so I relied on the k-member to guide it into place. Both sides look about the same on his car (both higher than stock) and I don't remember how long it took for my pro kit to settle in after the installation.
Old Jul 2, 2007 | 05:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i have the same problem so i would like to know too
Old Jul 2, 2007 | 07:33 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Crazy Hawaiian had it right, it turns out that the springs aren't seated properly in the k-member. i jacked it up and looked through the a-arm. The spring is too far outward and will probably drop a good 1.5 inches when it's seated properly. We didn't have time to fix it today. I'll try to take a picture of what it looks like out of position so others can refer to this thread in the future if they have a similar problem.
Old Jul 2, 2007 | 07:40 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
im going to have to check that
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
