What exactly does a wonderbar do?
Old Jul 9, 2007 | 04:09 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Search never works for me, so if this has been posted, I apologize. Anyway, what does a wonderbar do? I'm thinking about re-doing my front end before a motor swap and this looks like it could be interesting. Thanks, KP.
Old Jul 9, 2007 | 04:32 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: What exactly does a wonderbar do?
This is off the Spohn website........................
WONDERBAR.......This brace is designed to stiffen the front sub-frame and reinforce the steering box mount. This area is well known to be problematic on the third generation F cars. The tubular steering brace will not only provide for firmer steering response, but it will prevent the sub-frame stress cracking problem caused by the flex of the steering box. That's why the "Wonder Bar" is considered a must do upgrade on any third generation F-Body.
Old Jul 9, 2007 | 04:47 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Its basically a sub-frame connector for the front sub-frame. I got one from TDS and it makes a huge difference in steering and handling. You will notice the change as soon as you start driving after you put it on.
Old Jul 9, 2007 | 05:58 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Only the IROC was equipped with the Wonderbar--apparently because the 16-inch wheels caused stress cracking in the steering box area. That in itself, whether you're running 15 or 16's, is worth considering the Wonderbar. Personally, I doubt that you'll feel a difference.
JamesC
Old Jul 9, 2007 | 07:31 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
That is why they call it a wonder bar because you wonder what it is suppose to do.
Old Jul 9, 2007 | 08:56 PM
Kevman's Avatar
Engine: 2004 LQ4
I got 16" Irocs on my car.. And the whole front end feels like its lifting off the ground when I take turns fast.. Would this prevent flex in the front end?
Old Jul 9, 2007 | 10:26 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
no, sounds like suspension issues. Subframes and strut bar, with good shocks and springs should help you out.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
snakeshooter
Sep 10, 2015 07:46 AM
toosloz
Carburetors
Dec 12, 2001 12:02 PM
