Center Link - DIY?
Old Jul 23, 2007 | 07:13 PM
Pnormandin's Avatar
Center Link - DIY?
I have an '84 Z28 305 that just failed inspection due to the center link being garbarge. Is this something I can get in there and change myself. I have experience doing ball joints, tie rod ends, etc...but never this piece. I am hoping to hear some opinions from those of you that have tackled this before.
Also, does anyone have any good links to some suspension parts websites?
Thanks guys.
Old Jul 23, 2007 | 07:18 PM
dustpusher's Avatar
Car: 88 IROC-Z
Re: Center Link - DIY?
If you have done tie rods and ball joints center link is going to be very easy.
Old Jul 23, 2007 | 07:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Center link is easy since it's non adjustable. Remove the left and right inner tie rod ends. Remove from pitman arm, remove from idler arm and it's out.
Now once it's changed, you should still go in for an alignment.
Old Nov 7, 2008 | 08:14 AM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
Does the pitman arm connection to the center link need a seperater tool or anything?
As best I can see it is just a nut (and prob cotter pin)??
Old Nov 7, 2008 | 09:20 PM
Guest
Guest
Posts: n/a
Yes, you'll need something. Its a tapered joint just like the tie rod ends.
Old Nov 7, 2008 | 10:08 PM
Car: 92 Camaro RS
Axle/Gears: Stock
OK cool, I am doing everything (tie-rods/idler arm etc) so I'll have the separator. Just checking, thanks
Old Dec 23, 2008 | 08:15 AM
kymission's Avatar
Is there a tool for installing tie rods
I know there is a tool for everything. Removing tie rod ends is very easy with the proper tool. What about putting new ones in. Since it is a compression fit. Is there a tool to compress the tie rod back on to the nuckle or is it just the torque spec that does the job?
Have all apart, getting ready to put back together.
Old Dec 23, 2008 | 04:29 PM
Car: 92 Camaro RS
Axle/Gears: Stock
Re: Is there a tool for installing tie rods
I just torqued mine in to spec (do final torques at RIDE HEIGHT) I believe it was 34lbs all round
gta892000
Aug 11, 2019 11:16 AM
PurelyPMD
May 5, 2016 04:57 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
codeysabatini
Sep 20, 2015 11:36 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
