4th gen front wheels?
Old Aug 4, 2007 | 10:17 AM
shaolink9's Avatar
Car: 1986 z28 <sold>
Engine: iron head 383
Transmission: th350
Axle/Gears: 4th gen 3.23 posi
so i got my 4th gen posi rear end in today!!....the wheels stick out im sure u knew this :-\ I want to put 4th gen wheels on to fix this i know the back will not need spacers but will the front?? nd what if i do not use them.???? Any feedback would be great thank yall.
Old Aug 4, 2007 | 10:30 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: 4th gen front wheels?
The fronts will need spacers to use 4th gen wheels.
Old Aug 5, 2007 | 08:44 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
The 4th gen rear is now 4" wider than the old one. So the wheels are sticking out an extra 2" on each side. To fit 4th gen wheels on the front you will deffinitely need spacers. Skute.com has lots of info on this.
Old Aug 7, 2007 | 12:12 PM
shaolink9's Avatar
Transmission: th350
thnx guyz. any 1 know where to find cool wheels to fit on third gens?
Old Aug 7, 2007 | 08:13 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I have an '87 IROCZ with 16"x8.0" wheels, stock. I upgraded to the 1LE brake package. Now I purchased 17x9.5" 4th gen wheels with 54mm offset. I have 1.75" adapters (not spacers) on the front for these wheels. However, I did not like how close the wheel flange comes to the ball joints, so I added a 1/8" spacer. If you have factory disc brakes on the '86, then you most likely need 2.0" adapters on the front.
BTW: factory 17x9.5" wheels 4th gen wheels have 50mm of offset.
Old Nov 28, 2007 | 05:42 PM
kscamaro89's Avatar
Car: 2002 MINI Cooper S
Engine: 1.6L Inline 4 Supercharged
Transmission: 6 SPD
So I take it 4th gen bolt pattern is 5x4.75 also? or it just a close match in mm?
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
wruiz
Aug 11, 2015 02:59 PM
