Wheel bolt pattern question real quick
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
I found some wheels i really like but the pattern is 5x120. i know our cars are 5x120.65 or something close will that make a big difference or no. By the way the wheels are probably going to be 8" wide in the front and 9.5" wide in the rear would it be best to get the +20 offset or the +40?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Wheel bolt pattern question real quick
Small GM bolt pattern is 5 on 4-3/4". It's not a metric pattern.
Backspace is the distance from the inner lip of the rim to the mounting surface on the back of the rim.
Offset is the distance from the mounting surface of the rim to the center of the rim. Offset isn't too critical of a measurement but having the incorrect backspace can cause lots of problems. Knowing the offset is more common on front wheel drive rims because the backspace is so high to tuck them under the fenders.
Car: 1991 Camaro RS
Engine: 357cid
i see what you are saying about the offset... i was mixing it up with the backspace
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
5x120 is a diff bolt pattern and NOT a 3rd gen bolt pattern.
I believe it is for newer GM's.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
4 3/4 converted to metric is 120.65mm, anything other than this would be an issue
IIRC the 120mm is the BMW bolt pattern.
I've heard of people interchanging those, but I suspect that it's alot like the "what's the biggest size tire I can put on my stock pizza cutter wheels" typ of thing. What looks like it'll "fit", and what will actually work right, are 2 different things.
But, to put the size difference into perspective, .67 mm is about .026".
Car: 1991 Camaro RS
Engine: 357cid
I dono. The shop i work at is right next door to a tire shop so i'll ****** up a set of Bimmer wheels and see how well they fit. I do know of people putting BMW wheels on our cars and have personally seen it too. Well either way i'll keep you updated
84z96L31vortec
Aug 20, 2017 12:16 AM
