How to lift my rear?
Old Sep 11, 2007 | 11:46 PM
  #51
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: How to lift my rear?
I'm surprised no one mentioned this, but where the rear shock mounts on the body is barely reinforced. A car from the rust belt can even have these mounts broken through with only new shocks. If you go the air route, reinforce that area! Unless you want to be driving along one day, hit a bump, and then have your shocks join you on the inside of the car.
Old Sep 11, 2007 | 11:52 PM
  #52
i_love_thirdgen's Avatar
Car: 92 camaro,99 s10
lol,you know what... i didn't even think of how flimsy it is on the body
Old Sep 11, 2007 | 11:53 PM
  #53
85camaronetta's Avatar
Car: 85 Camaro Berlinetta
Engine: 2.8l V6
Transmission: 5 spd
I inquired about this but wasnt sure. My mounts are in great shape and I dont plan on usin them to raise the entire rear weight of the car, just want a little lift and adjustability. Plus I wont be carrying anything in it anyhow. Should be fine...right?
Old Sep 11, 2007 | 11:55 PM
  #54
Axle/Gears: 3.27 BW
Well, you're going to be raising it over stock height, with stock springs. The springs will expand a little, but will be supporting MUCH LESS of the body once you get above stock height. Even those Moog CC springs will only give you a little bit more leeway. The higher you get from stock height will only increase the amount of force on the mounts. I'd reinforce them. Definitely cheaper insurance to have them reinforced now instead of having them repaired when they bust through the metal.
Old Sep 12, 2007 | 12:04 AM
  #55
Engine: 2.8l V6
Transmission: 5 spd
How would you suggest doing this?
hectre13
Dec 11, 2023 08:14 AM
krisb410
Mid-Atlantic Region
Mar 11, 2016 09:21 PM
bdads
Aug 24, 2015 06:01 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
anesthes
Aug 8, 2015 09:37 PM
