sway bar end links
Old Sep 4, 2007 | 09:36 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
sway bar end links
went to the bogus basin hill climb this weekend and on my first run i slid off (front end pushed) and buried the nose into the hill side. when i got the car to the pit area i found the end link of the rear sway bar had pulled through the eye of the bar,the lower bushing and washer were gone but the bolt and nut were still there. this is the third time this has happened. the first time it was the front sway bar and resulted in a very nasty accident. however i think it was my fault in material used. the last two times its been the rear bar... has anyone else had this kind of problem or could it be a design flaw on my part. the end links on the rear are mounted solid to a bracket (with a bushing on each side of the end link) that is bolted to the body. where as the front uses a 6 or 8 in bolt and spacer with 4 bushings per side the rear uses a 3 or 4 in bolt and 2 bushings per side. do i need to put the rear back to stock design to allow more movement? any ideas will be apprecated.....thanks tao
Old Sep 4, 2007 | 09:45 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: sway bar end links
There's supposed to be 4 bushings per endlink for the sway bar to be effective.If you are only using 2 per side then it's like the bar isn't there.And the front and rear uses the same end link length and use nylon lock nuts also.
Old Sep 4, 2007 | 09:54 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I think that stock set-up with poly-urathane bushings would be better. I've really beat on my car for 3 years now, and I've never had a sway bar failure (after replacing the 15 year old stock bushings with polyurathane).
Old Sep 28, 2007 | 11:03 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
This JUST happened to me. I have a complete stock suspension. I dont drive my car too hard, it happened while going over a bump probably.
1992rs/ss
Jan 31, 2025 05:10 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
