9 bolt torque arm?
Old Sep 9, 2007 | 09:54 AM
carbediroc's Avatar
9 bolt torque arm?
Is the torque arm any diffrent for the 9 bolt rear the only reason I ask is every one I look at says it fits the 10 bolt I am sure they are the same but that is my next purchase so thought I would ask and for a daily driver and limited strip time car is the adjustable arm worth the money?
Old Sep 9, 2007 | 10:20 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: 9 bolt torque arm?
do a search..there is a member on here i forget his name...the edelbrock torque arm can fit on the 9 bolt rear, but you have to shave something off of it to work....he says it works fine. i was going to do that but i am getting a lt1 rear end in my car so i am just waiting until i put that in there.
Old Sep 9, 2007 | 05:05 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The torque arms are the same for both 9-bolts and 10-bolts. The only difference is the early thirdgen years have a torque arm facing a different direction than the later thirdgen years. That is fixed with a torque arm mount swap.
Old Sep 10, 2007 | 05:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Another member and I went through this a couple of years or so ago. The Edelbrock fit my 10-bolt without a hitch. He was forced to slightly modifiy his at the axel end in order for it to fit:
https://www.thirdgen.org/forums/tran...questions.html
Here's a pic Synapsis took:
https://www.thirdgen.org/forums/atta...quearm-end.jpg
My "guess" is that the OE piece is curved to accomodate both 9- and 10-bolt rears.
JamesC
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
