''IROC'' springs
Old Sep 19, 2007 | 05:07 PM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
''IROC'' springs
Yes, i searched but nobody said wheather or not the w6 springs were better or worse or the same as the iroc springs.I'm looking for a spring to improve handling but ''NOT'' to lower my car thanks for any input you may have..thanx
Old Sep 19, 2007 | 08:29 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: ''IROC'' springs
they are the same given the same RPO spring codes. BZW and BZX front springs are fairly common IROC/WS6 springs, with NNL being the rears.
Old Sep 19, 2007 | 09:12 PM
eschevyrda's Avatar
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
na but what i want to know if its true that the irocz are .5 lower then the base coupe
i read that on here
is it the springs or the entire iroc package
and will the iroc springs that spohn sell give it a stance or what
Old Sep 19, 2007 | 10:04 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
i just bought the 5662 and 5665 moog's from summit for 125 shipped, got the fronts today, supposedly get the rears friday. the fronts look pretty tall right now though, i'd say a 14" free height. they're supposed to be stock height. that seems about right to me from what i was reading before i bought them.
Old Sep 19, 2007 | 10:19 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
My 5662 springs were shorter (free height) than the stock BZW springs I took out of my IROC, they were also a thicker wire tha the stock ones.
Old Sep 20, 2007 | 01:00 AM
eschevyrda's Avatar
Car: 89camaro rs
so does any one have pics of thier car with the moog iroc style springs
Old Sep 20, 2007 | 01:06 AM
Car: 92 RS
Engine: a slow one
Yes, my new ones also seem to be thicker than the ones on the car, but I can't comment on the free height of the stock ones until I pull them out. When I install the new springs I'll take a side profile picture to compare with my signature pic.
Old Sep 20, 2007 | 04:09 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
So what is the difference between the bzw and the bzx?i dont want to lower it i just want it to handle better than my worn out stockers.So im guessing that my best bet would be to order the moog springs if i want a stock spring correct?could i not get the stock spring from the parts store?
Old Sep 20, 2007 | 06:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
FYI. My 5662 fronts sit at a smidge below 27 inches, the rear higher. I purchased mine at CarQuest and saved a bit of coin.
JamesC
Old Sep 20, 2007 | 11:55 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
Originally Posted by JamesC
FYI. My 5662 fronts sit at a smidge below 27 inches, the rear higher. I purchased mine at CarQuest and saved a big of coin.
JamesC
And you got stock rs springs or iroc springs?
Old Sep 20, 2007 | 03:36 PM
JamesC's Avatar
IROC.
JamesC
customblackbird
Aug 15, 2021 10:16 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
mustangman65_79
Aug 11, 2015 03:17 PM
