how big
Old Nov 1, 2007 | 09:07 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
how big
what is the largest street tire that i can put on the back of my car? stock ride height. i use mt et streets for the track getting ready to buy some new street tires wanting to put the tallest, fatest tire i can put on the back without rubbing. and probly a 165 r15 on the front. also what size backspace do i need for a 15x3.5 weld prostar?
Old Nov 5, 2007 | 05:45 AM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: how big
anyone?
Old Nov 5, 2007 | 05:56 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: how big
First...........WELCOME to the board.
You can put a 275 50 15 on the rear and maintain the stock height (they are 25.9" tall). They will fit a 7.5 - 9.5" wide rim.
For the 3.5" go with no bs or minimal.
Old Nov 5, 2007 | 08:42 AM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
Re: how big
I got 295/50x15 for my street tires, it keeps the car at a good height.
Old Nov 5, 2007 | 02:03 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: how big
the only smallest backspace i can find is 1.75 ive heard that on the 4th gens you have to run spacers because they hit the calipers does that hold true to the thirdgens as well? i was also wondering what size rear wheel should i run and what backspace? i like the idea of the 295's do they rub anywhere?
Old Nov 5, 2007 | 02:11 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
Re: how big
15x10 rim with 5.5 backspacing, 295's are a tight fit, but no rubbing
Old Nov 5, 2007 | 07:29 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: how big
anypics? did you have to roll the fenders? and its a 295/50/15?
Old Nov 5, 2007 | 11:26 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
Re: how big
Rolling the fenders would be a good idea with any tight fit tire, but it's not needed. I only have one pic recently but it's not of the rear tires it's just a general shot. My street tires are dunlop gt qualifiers, not the stickiest out there but I don't need to be spending a lot of money on sticky street tires, that's what slicks are for.
Old Nov 6, 2007 | 07:35 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: how big
does anyone have prostars or draglites up front 15x3.5 and did you have to use a spacer or grind a the calipers?
Old Nov 7, 2007 | 01:01 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: how big
on a thirdgen with factory brakes, you dont need spacers..
Old Nov 7, 2007 | 09:09 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: how big
ok good what is the biggest tire you can fit with a 15x8 4.5 inch backspace?
Old Nov 8, 2007 | 02:08 AM
5678TA's Avatar
Car: 1984 Trans Am
Re: how big
275/60-15 its 28" tall
Old Nov 8, 2007 | 04:15 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: how big
I have 8.5 inch wode convos, i have 295/50/15 and they work great, no rubbing, i do have rolled fenders. They ride a bit loose in the rear buy that is because it is not a short side wall, they are BS tires too, nothing special.
Old Nov 8, 2007 | 10:32 AM
radialtireking's Avatar
Car: 85 Camaro
Engine: 437" small block
Transmission: glide
Axle/Gears: 3.70
Re: how big
1.75 back space will fit fine with no spacers. I have them on the front of my car.
Old Nov 9, 2007 | 01:07 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: how big
you can fit a 28 inch tall tire on with stock ride height? i thought it would rub.
Old Nov 9, 2007 | 03:52 PM
5678TA's Avatar
Car: 1984 Trans Am
Re: how big
i'm running 28.5's with stock rear springs.. it only rubs when i launch it hard..
Old Nov 9, 2007 | 04:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: how big
My 275/60/R15's are 28" tall and fit fine on stock ride height without rubbing. On 2nd gen snowflake 15x8 wheels.
It needs the fenders rolled though, it slices the sidewall sometimes.
Old Nov 10, 2007 | 06:29 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: how big
what is the backspace on yours?
Old Nov 12, 2007 | 01:42 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: how big
on a forth gen i have seen that you can put on a 15x10 w/ a 5.5 inch backspace and fit a 325/50/15 with that work on a thirdgen or is it way to big?
Old Nov 16, 2007 | 04:30 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: how big
Think it is a 4.5 BS.
Old Nov 16, 2007 | 09:32 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: how big
i ordered my prostars monday they all came in one of the rears was damaged so summit is sending me another one. i bought 15x3.5s up front with 165/80/15 kumhos, and the rear i bought 15x8s with a 4.5 bs. as soon as i can get a set im getting 275/50/15 mickey thompson et street radials for the back. everyone around is out of them because of the world street nationals.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
dusterbd
Sep 29, 2015 08:40 AM
