subframe question
Old Nov 25, 2007 | 04:10 PM
kevingrealish's Avatar
Car: 84 Z28
Engine: 350 V8
Transmission: 5 speed
subframe question
I was in a wreck last week and smashed up the front drivers side of my 84 camaro. I found out that the sub-frame is bent - pushed right about 1 1/2 inches. Can I replace the sub-frame itself or is my car dead?
Old Nov 25, 2007 | 07:25 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Re: subframe question
Kev,
Front subfame (K-member) is completely replaceable. The K-member is positioned on the unibody frame with two alignment dowel pins. In an accident, the pins can rip the alignment hole in the unibody & make a mess. Depending on the extent of damage, you may need a body shop to do the frame repair. Or you may luck out & be able to swap it out. Looks like you got a trip to the bone yard in your future. If you get into the job & need some help let me know. I completed a swap last spring.
Corky
deracer
Apr 11, 2016 12:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
