Energy Suspension Bushing - Require maintenance?
Old Jan 30, 2008 | 12:27 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I just got the master set of energy suspension bushings for the front end of my car. When I picked it up the mechanic said I should be wary of regreasing them every year.
Is this true and if so, why?
Curious about this...
Old Jan 30, 2008 | 05:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Energy Suspension Bushing - Require maintenance?
With the exception of the greaseable sway bar bushings (TDS), I've never lubed any of the ES stuff--and I've got a ton. No ill effects that I can see or hear.
JamesC
Old Jan 30, 2008 | 09:10 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Same. If you ever get your hands on the grease that comes with the ES poly bushings you'll understand how puddle splashes will NEVER wash this stuff away. (It takes a LOT of effort to get your hands clean, I mean a lot).
Mine haven't squeaked yet. If you ever notice it does start to make noise, you can always disassemble that part and add some poly grease (white silicone grease IIRC). I wouldn't do it as preventative maintenance like an oil change or pumping grease into grease nipples though.
Old Jan 30, 2008 | 04:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its white lithium grease, not silicon
Old Jan 30, 2008 | 04:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
Right! Slip of the internet-tongue.
Old Jan 30, 2008 | 05:41 PM
Guest
Guest
Posts: n/a
Sure, tons of maintenance.
I've had ES poly on my car for 15 years now, havent done a single bit of this 'yearly maintenance' nonsense.
Old Jan 30, 2008 | 09:29 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
My sway bar bushings have zerks so I give them a shot once in a while when I'm under the car. Have never done anything to the rest of them.
I used to have a set on my old Dodge that squeaked unless you gooped them up every few months.
Old Jan 31, 2008 | 11:39 PM
Cadillac's Avatar
That's what I was like when the guy told me.
Holding on to the white lithium grease.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
starfinder
Oct 25, 2015 10:40 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
