Wonderbar Question.............
Old Feb 17, 2008 | 10:11 PM
Rumblin70SS's Avatar
Car: 88 IROC-Z T-Top car with Bose
Engine: L98 5.7
Axle/Gears: 9 Bolt with 3.27's
Hey all,
Just a quick question..........been thinking about picking one of these up since my B4C car doesn't have one. In looking at how it works by tying the front subframe together, I have to ask, doesn't the front swaybar kinda do the same thing? I realize it moves slightly, but I figured it would still do the job.
I might be missing something, so any help is appreciated.
Old Feb 17, 2008 | 10:16 PM
Uglybronco's Avatar
Car: '70 Bronco, '91 Firebird, '03 Chevy
Engine: roller 302, 350 TB, stock 6.0
Transmission: NP435 Granny 4 spd, 700R4, 4L80E
Axle/Gears: 4.56 spool, 2.73 open, 4.10 broken
Re: Wonderbar Question.............
No, the swaybar bushings only fit around the swaybar & is able to slide side to side. It offers virtually no resistance to the flexing of the frame... Does about as much good as an appliance plugged in does to hold a wall in place.
Old Feb 17, 2008 | 11:07 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I didn't understand until I actually put mine on. The sway bar offers no support to the frame rails since it is able to slide back and forth in its bushings. The wonderbar connects the two frame rails together using the same holes the sway bar bushings use.
Old Feb 18, 2008 | 12:29 PM
Engine: L98 5.7
Hey guys,
Makes sense now with the swaybar moving in the bushings........I'll pick one up and hopefully make the car feel a little more solid!
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
snakeshooter
Sep 10, 2015 07:46 AM
toosloz
Carburetors
Dec 12, 2001 12:02 PM
